PWK design for trunk wall - Car Audio Classifieds!
Old 08-20-2013, 12:29 PM
Burkem_10's Avatar
0/11 ssssss469
Default PWK design for trunk wall
I thought I would write about my experience with PWK's enclosure design service, which I have utilized twice now.
If you don't know about PWK he offers an enclosure design service that is supposed to find the optimal enclosure based on your specific vehicle, the maximum space available for an enclosure, and your subwoofer/amp combo. In his videos there is a bit of a 'wow factor' because he shows enclosures like transmission lines and horns which can have surprising amounts of output given the low amount of power and cone area used. See his "What's in my trunk" videos for reference.
http://pwkdesigns.com/
The HexiBase Channel - YouTube
My first experience
I submitted a rather specific form asking for a horn and was never replied to. I asked around a bit and found out that he doesn't necesarily take requests like that since a horn may have not been what was optimal for my setup with the listening goals that I gave him.
There is a chance he replied and it got caught in my spam or I mispselled my e-mail or something...
My second experience
I sent a request for 2 12s with about 5-6 cubic feet or airspace. I don't know what I was thinking but I expected something special. Stupid me didn't realize that with that airpsace and two 12's you can't do much better than a ported box. Well, the one he designed was nearly spot on with the one I already had so I didn't build it. I did however give the plans to a friend who also had two SA-12s, similar power, and the same car as me. He said they sounded pretty good. Still, not worth the ~$65 I spent but I shouldn't have expected anything other than a ported box in the first place.
The only real difference between my box and the one PWK designed was that mine had one port and both subs shared the airspace where his has each subwoofer in its own chamber. The tuning, airspace, port area, etc were all nearly identicle.
Enclosure: 15.5H x 35W x 22D (Inches)
Driver: Sundown SA-12 D4 12" x 2
Powered by 1 Cadence ZRS-C1
Performance: 30Hz - 70-80Hz, Audible Performance
It took 8 days to get this design.
My third experience
This time I wanted to see what I can do with a single X-12 in my car. I figured that one 12 in an efficient enclosure like a 6th, horn, t-line, etc would be pretty impressive and I don't trust myself enough to design those. So, I waited until PWK was able to get his hands on and review the Xs before I submitted a request.
I thought for sure giving him nearly my entire trunk to work with would result in a rather efficient enclosure that can produce some "wow" reactions. I'm going for 'SQL' so I specified that I want audible performance rather than spl with extention down into the upper 20hz region.
Thank you for your PWK Designs project assessment inquiry.
I've just now gotten a chance to review it and it looks like your maximum available external dimensions offer us around 141 liters of loading volume, which is more than sufficient for a very impressive design, with solid performance well into the upper 20Hz region. Keeping the height / width at its maximum shouldn't be a problem, though we'll most likely be able to bring the depth down a tad.
Enclosure: 14H x 32W x 24D (Inches)
Driver: Sundown X-12 DVC 4 ohm x 1
Power: ~1600W
Goal: Listening Purposes
Music: Hip-hop, dubstep, indie pop
I would like the enclosure to be semi-walled (sealed off from the
trunk) and for that to happen the given max width and height need to
be used but I suppose there can be some leeway. <br />
<br />
This is intended to be a 'SQL' build and extention down into the upper
20hz range would be appreciated.
It took 17 days to get this design.
So there's the design I got - a ported box. I'm going to build it and see how it works out and hopefully I'm not let down lol. It looks to be about 2.75 cubes @ 33-34hz with 16 square inches of port area per cubic foot. It's not exactly what I expected to receive but I will update this with how it sounds when I do get it built. It still kind of sucks to pay $65 for something I could have designed myself. It's actually very similar to the enclosure I have it installed in right now. Im tuned a bit lower with a little less airpsace though...
Overall
Price - 6/10 (Would be higher if they weren't boxes I can design myself)
Communication - 9.5/10
Lead Time - 8/10 (I may be more patient than most)
Design Quality - 9/10 (The pictures are accurately labeled and documented - A cut sheet would be nice though)
04 GP - SQL-ish
X-12 in a trunk wall
JBL GTO1400
Cadence ZRS-C9
HAT Imagine 6.5s active
Rockford Fosgate 360.3
Old 08-20-2013, 12:53 PM
Mr.G6's Avatar
0/11 sssss4614
i just keep money
screw paying 65bux for a design.. you wASted your money
2000 Gmc Sonoma ext cab
Old 08-20-2013, 12:56 PM
Ryan1126's Avatar
0/11 sssss9178
Feedback Score: 59 reviews
so basically your conclusion is that you can almost design a box as good as pwk?
Old 08-20-2013, 12:58 PM
0/11 ssssss298
I think his conclusion is that he was expecting more than a simple ported box for $65
The Following User Says Thank You to DRS0105 For This Useful Post:
Burkem_10 (08-20-2013)
Old 08-20-2013, 12:59 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
its a service.
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
Old 08-20-2013, 01:15 PM
logan23afroman's Avatar
0/11 sssss1813
Feedback Score: 30 reviews
Originally Posted by goatskindreams View Post
its a service.
An ass rape service lol
"Loudest Jeep Commander"
4xSundown sa-8''s
aq1200 with dual 0 gauge inputs!
141.6 on dash at 48hz with 594 clamped watts
The Following User Says Thank You to logan23afroman For This Useful Post:
markc32 (01-27-2014)
Old 08-20-2013, 01:18 PM
Do you even demo?
0/11 sssss1797
no one forced him to pay
The Following User Says Thank You to goatskindreams For This Useful Post:
Old 08-20-2013, 01:20 PM
djscrubb's Avatar
Captain $hit disturber
0/11 sssss2332
Just like a huge drum roll........
..fail then you realize its no more better then what you could've designed double kick in the nuts ivr also contacted him and couldn't get over how arrogant he is. "Remember its not what your box is tuned to is the acoustical interaction between sub box and vehicle." Truly amazes me how full of them selevs some ppl are
Old 08-20-2013, 01:32 PM
he is right....
The Following 3 Users Say Thank You to korey_hofer For This Useful Post:
Anton Miller (08-20-2013), Burkem_10 (08-20-2013), lileddie1127 (08-20-2013)
Old 08-20-2013, 01:39 PM
tony30cl's Avatar
WE DEM BOYZ
0/11 sssss7525
Feedback Score: 22 reviews
this is why i can understand his frustration... dont tell him what you want IE horn etc.... obvious reasons...
Sealing off trunk wall jd93kid General Car Audio Discussion & Questions 21 06-24-2013 12:48 PM
trunk wall? smokenyall General Car Audio Discussion & Questions 31 04-10-2012 06:32 PM
sealed off trunk mini wall help?? jaeguerra909 Enclosure Discussion & Design Construction Help 4 10-16-2011 06:19 PM
pwk design modification help bottlefed1 Enclosure Discussion & Design Construction Help 48 03-09-2011 08:43 PM
Need Help With A Trunk Wall/Box Design. partyboy6686 Enclosure Discussion & Design Construction Help 2 09-26-2010 11:47 PM
