New Incriminator stuff - Car Audio Classifieds!
Old 02-24-2015, 09:05 AM
0/11 ssssss241
Default New Incriminator stuff
Looking for opinions on the new stuff as it seems as if people are side stepping their amps.Any input would be appeciated.
Old 02-24-2015, 09:37 AM
0/11 sssss1475
Not trying to stir the pot just pass on some info. There is an amp test t-fade did with big power amps. The IA 80.1 didn't do rated power. Was told he needed higher voltage to make rated power.
Flame suit on.
Old 02-24-2015, 10:00 AM
IS300IAdeathRow's Avatar
0/11 sssss3693
Feedback Score: 42 reviews
I'd def agree that their amps are more geared to high voltage performance. I loved my ia20.1's but I also did read t-fades results and was very surprised to hear his outcome. Such a big amp and didn't get to its rated....but I'll bet at 14-16v it would throw out some serious juice
2013 Toyota Highlander
Build to come.....
Old 02-24-2015, 10:10 AM
Sencheezy's Avatar
0/11 ssssss483
From what I've heard, yes, HV amps.
165db with 237 DC Volts
6 15" SSA Evils
3 HV Taramps T60k @.33
18 XS Power D3400s
Add me on SC, FB, IG, and YT @ Sencheezy
Old 02-24-2015, 10:43 AM
0/11 ssssss644
if your interested in the older stuff I have a 40.1 V1 im trying to sell. PM me if interested, sorry for the thread jack...
Old 02-24-2015, 10:44 AM
1loudmonte's Avatar
Team Incriminator Audio
0/11 sssss2167
Feedback Score: 36 reviews
I can vouch for the IA stuff as I run there equipment. The 20.1s clamped 29xx @ .35 rising to [email protected] 12.8 volts clean, 3550 wired @ .35 rising to 1 @ 12.8volts with a slight clip. The 40.1s clamped 5140 wired at .4 rising to 1.25 @ 13 volts clean, 7xxx wired at .35 rising to 1 @ 15 volts on a 16 volt system. I can say anything about the 80.1s as I have not used or seen them in person. DO they shine on high voltage YES, but what amp doesn't make more power at a higher voltage. Don't hesitate to try the 20.1 and 40.1s. They will do there rated power with no problems.
(2015 MECA Street 3 World Champion)
2004 Dodge Ram Single Cab 1500
3 Incriminator Audio Judge 15s
3.25:1 Ratio 4th Order Blowthrough
1 x AA 9.0 TFHE, 2 x AA 150.4
4 X Crossfire XS-M8's, 2 x PRV Tweets
Old 02-24-2015, 10:54 AM
0/11 ssssss241
OK 1loud monte thats speaking of the new stuff right?Not the older stuff we all knew that was pretty awesome stuff.
Old 02-24-2015, 11:21 AM
1loudmonte's Avatar
0/11 sssss2167
Yes that's the new stuff, I have all the 2013 and up stuff and love it.
Old 02-24-2015, 12:34 PM
HiloDB1's Avatar
0/11 sssss3158
I've run the new IA20.1, IA10.1, IA80.1, Lethal Injection, and Warden subs. Cant say anything bad about them as they have all performed great. I have never clamped the 80.1 so I cant say anything about what it will actually do.
Old 03-02-2015, 11:08 PM
So Low's Avatar
0/11 sssss1258
As far as amplifiers go, I am not worried about what an amp is rated for at nominal loads, I want them to make power on my load. Practically speaking, two amps rated at the same power at the same load, are going to deliver power very differently based on how low one can safely wire that amp to minimize reactive load. If one amp wires at .3 and does 4k is more useful than one that protects under .7 but will do 3k at .7 nominal. IA did a great job with these amps as far as making them almost bulletproof. I've wired my 20.1s at .175 ohms, slow Rollin like you wouldn't believe, but they cooperated. On 12V you could probably run them at .25 daily.
I think people back off based on the price tag, and I understand that, but when I went to 14V batteries charging high 17s I couldn't resist trying the IA lineup based on what I heard about their high voltage operation and was baffled at how such a little, albeit heavy amp could make so much power. I immediately bought 3 more.
Fiddling with line driver voltage I got some clamped numbers;
Starting 17.6V
Drop to 16.2V
.72 ohms rise from .21
5129 Watts
So in my mind, I think that price tag is reasonable for getting 5k out of it. I think it does close to 6-7k at 19V
WTT: Stuff I don't need for stuff I do need. jking29 Car Audio Trader (WTT) 13 05-27-2014 01:35 AM
Stuff that I want to trade for! :) ... YES TRADE YOUR STUFF FOR PSI SUBWOOFERS/PARTS! TeamPSI (Fix My Speaker) 53 03-01-2012 01:12 AM
RC Stuff(lots of great stuff, hobby grade too) SPLLuminator Miscellaneous Stuff For Sale 35 12-24-2008 02:24 PM
just my kind of place....stuff for sale....I love buying stuff I dont need gentlejax2 New Member Orientation 4 08-02-2008 10:41 PM
