Taramps 8k 2 ohm - Car Audio Classifieds!
Old 07-11-2015, 03:26 PM
crownvicon26's's Avatar
0/11 sssss1882
Default Taramps 8k 2 ohm
Just want to do a quick review of this amp. I originally had a CT sounds 4k wired to .5 ohm. By having a 4th order trunk build I was limited on space and had no choice but to mount the CT on the box knowing this could potentially cause issues due to the amps lack of board support. Long story short the amp has been very unreliable, thus my decision to try a Brazilian amp. Got the amp installed today wired to 2 ohms. With this amp having a rather small footprint for its size I was able to mount it on top of my batteries but I also had other mounting locations to choose from because of its size. I know an efficiency comparison is not apples to apples but I was living in the mid to low 12's with the CT and now I don't drop below 13.2 even at idle full tilt. It also seemseems a good bit louder. It plays as low if not lower than the ct. I played it for about 2 hours straight today and it was only warm. Im very happy with this amp but it may be a little too much for my subs. They get a little smelly after about a minute or two of hard wangin. Not as technical as other reviews but I'm sold on these amps after being skeptical at first.
Taramps 8k
2 Zv.3 15's
2.87:1 4th Order @ 48hz
Old 07-11-2015, 03:36 PM
craiggus365's Avatar
Partially Unwound
0/11 sssss2697
Good review, sometimes the biggest isn't the best.
I really would like to try one of these style amps also, they just never show up as a refurb or small ones used. (Cheap-o = Me!)
I really loved 'the little smelly after hard wangin' line.
The Following User Says Thank You to craiggus365 For This Useful Post:
crownvicon26's (07-11-2015)
Old 07-11-2015, 03:42 PM
0/11 sssss1882
Lol. They put out a good bit of power. Try facebook. That's where I found mine.
Taramps 8k
2 Zv.3 15's
Old 07-13-2015, 09:51 PM
0/11 sssss2148
Feedback Score: 26 reviews
Nice review and yeah with that much power on tap I can image they getting a little smelly lol......good stuff, I keep wanting to pull the plug and go 4th but dont know why I dont lol.
Old 07-13-2015, 11:01 PM
chasinbass's Avatar
0/11 ssssss247
Nice Bro ! I am watchin see how happy you are with it ? I am thinking of getting the 10k 2 ohm for my rebuild after the CT7k mess lol !
Old 07-14-2015, 09:14 AM
0/11 sssss1882
Do it bro. You won't have to worry about your trunk rattling and it's probably the most efficient way to get airflow into the cabin with these cars the way the trunk is made.
I am so happy with this amp. The only down side is no bass knob but that's cool. The 10k should be an absolute beast!
Taramps 8k
2 Zv.3 15's
Old 07-21-2015, 12:00 PM
0/11 sssssss34
Hey crownvicon26's what's your electrical like? I'm thinking about getting the same amp and am running a saz 3500 at .5 and keep hearing these things are less power hungry than sundown amps with alot more power.
Old 07-21-2015, 12:32 PM
0/11 sssss1882
1g31 up front, 3g31's in back, 3 0gauge runs, j's 275amp alt.
Taramps 8k
2 Zv.3 15's
Old 07-21-2015, 01:44 PM
mbrooky's Avatar
Team South
0/11 sssss1238
nice review man....and I felt the same...I had an rd d9 which is basically the same as the ct 4k and switched to a taramps 8k and I noticed the same as you. very happy with the 8k...so happy I bought 2 more! haha! also, for a bass knob, I picked up a pac lc-1 and works awesome
TEAM SOUTH bishes
TEAM RedStick
Team Hz Addiction
sa8 4th order trunk build:
The Following User Says Thank You to mbrooky For This Useful Post:
crownvicon26's (07-21-2015)
Old 07-21-2015, 02:57 PM
0/11 sssssss34
Yeah your electrical is a little more stout than mine. But thanks for the review man I've thinking about that 8k all week.
Taramps TS800x4 2 ohm Omegakan Multi-channel Amplifiers 25 01-27-2016 11:12 PM
Fs: Taramps HD 8k 2 ohm Beatdown337 Mono Amplifiers 0 02-06-2015 06:33 PM
FS: Taramps HD4000 2 Ohm Version $LICK CALIFA$ Mono Amplifiers 3 12-23-2014 09:41 AM
Taramps hd4000 2 Ohm model Allauto6293 Mono Amplifiers 3 12-04-2014 10:32 AM
FS : Taramps HD6500 1 Ohm Version ChevyBoy95 Mono Amplifiers 26 09-16-2014 01:57 PM
