Power is in the House!
Will do 4000 peak on burps @ 1ohm- and can be rolled on at .35, and stay cool all day unclipped!
Digital mono block amplifier
* Dual MOS-FET power supplies
* Efficiency over 86%
* RMS power handling---1000w @ 4 ohms @14.4V
* RMS power handling---2000w @ 2 ohms @14.4V
* RMS power handling---3200w @ 1 ohms @14.4V
* Signal-to-noise ratio 85dB
* Phase shift 0-180 degree
* subsonic filter: 10-60Hz
* lowpass filter: 35-300Hz
* Input sensitivity: 200mV -6V
* Bass remote controller with telephone wire & click volume & blue LED
* 3 way protection: over voltage, speaker short & thermal overload
* Total harmonic distortion:< 0.1%
* Continuously variable 0 18dB Bass Boost
* Built - in variable 0 18dB per octave xover
* Power Consumption< 320A
* Size: 23.25 x 10 x 2.20
You can find em for $550-575 or less new, and in the $425-475 range used.
