Just a lil Nendo / PPI Budget Build - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > Car Audio Videos
Car Audio Videos Post all your car audio videos here.
Old 04-03-2012, 10:44 PM
Loudizzzzle's Avatar
0/11 sssssss53
Default Just a lil Nendo / PPI Budget Build
https://www.youtube.com/watch?v=c7_HunkxKxk
https://www.youtube.com/watch?v=cNk0EPFOlFI
https://www.youtube.com/watch?v=-9PZOLEF9uw
Old 04-03-2012, 10:46 PM
0/11 sssssss53
https://www.youtube.com/watch?v=4DqVjbWqiSQ
https://www.youtube.com/watch?v=gfI8mjFeRVQ
Old 04-04-2012, 02:35 PM
0/11 sssss1475
I'm excited to get my 1100.4 in the car, how you liking it so far?
On a side note, you said in the last video that 4 Ohm and 8 Ohm parallel makes 6 Ohm. When connecting parallel loads the final resistance is always less than the lowest load. For two loads its product divided by sum, so in your case 4*8=32 divided by 4+8=12. Giving you a final load of 32/12= 2.66 Ohms. So you should be getting quite a bit of power out of that amp.
Old 04-04-2012, 03:52 PM
0/11 sssssss53
^^^^ HMMMM maybe that's why my CTS-1's blew! I should have put it on the DMM before I listened to it. Thanks! Learned something new today! Also love the c1100.4. It does a decent job on the 2 10's while being able to power the mids and highs nicely.
Old 04-04-2012, 06:29 PM
0/11 sssss1475
If there not rated for 250W that could be a reason... ha bandwidth could also be a reason, if you cross them too low it could cause them to blow. Are you running the tweeter straight to the amp without a highpass circuit? If so what frequency did you cross them at? Specs call for a 3KHz-28KHz bandwidth.
Old 04-04-2012, 06:46 PM
0/11 sssssss53
I ran the CTS-1's with the provided crossover that came with them. It was prolly too much power if the amp was being ran at around high 2's for ohms. It does decent power at that ohmage LOL. OOPS!
temporary budget build...94 xcab ranger (work truck build) CodyBrown2013 General Car Audio Discussion & Questions 8 02-17-2012 09:44 PM
SickNasty lil car build UpGradde Build Logs 22 06-03-2011 06:45 PM
best budget build Rd4me General Car Audio Discussion & Questions 19 09-11-2010 05:40 PM
How is this for a budget build. hornedfrog1985 General Car Audio Discussion & Questions 9 02-24-2010 05:45 PM
04PeeJays Budget Build 04PeeJay Build Logs 14 12-14-2009 06:45 PM
