How To Kerf Birch! Birch Kerfing tips! - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > Car Audio Videos
Car Audio Videos Post all your car audio videos here.
Old 12-23-2013, 10:34 AM
Josh Wahlie's Avatar
< Pic from my build log!
0/11 sssss3196
Default How To Kerf Birch! Birch Kerfing tips!
Thanks for watching. Feel free to ask if you have any questions.
Make sure to subscribe!
HOW TO KERF BIRCH!! Special Birch Kerfing Trick Revealed! - YouTube
Custom Box Builder (Ships all over the USA)
Shok Industries Dealer
Old 12-23-2013, 11:15 AM
cjvue's Avatar
0/11 sssss1028
Very nice! Great advice and awsome vid.
- TEAM SUNDOWN AUDIO -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Old 12-23-2013, 11:31 AM
0/11 sssss3196
I've just noticed from a few other tutorials that don't mention the simple things like grain direction & saw blade depth importance. I hope this helps anyone wanting to learn.
Old 12-23-2013, 12:06 PM
Eric B's Avatar
LowBlowBro
0/11 sssss2140
That's because it doesn't matter. It's plywood, not solid board. I've done countless radial bends in both grain orientations, makes no difference. The top (Finish) veneer is simply decorative, thin as card-stock paper. The core layers are all perpendicular from each other.
Also, there is a formula for kerf-cutting to achieve different radius'. Not simply just doing 3/8" O.C. every time.
1. Take the outside perimeter of the radius and subtract the inside radius perimeter. That tells you how much you remove.
2. Take the amount from step 1 and divide it by the thickness of the saw blade (kerf). That will tell you the number of cuts you are to do.
3. And for the final step you simply, take the outside perimeter of the radius and divide that by the number of cuts. That will give you the distance between your cuts.
I hope this helps you to teach people the proper way of doing things.
Old 12-23-2013, 12:26 PM
Veteran Member
0/11 sssss3359
Exclamation
i was gonna say something if u hadnt beaten me to it benda. some peoples kids
Tips on baltic birch benjdow Enclosure Discussion & Design Construction Help 14 03-26-2011 12:43 PM
How thick of Birch to use? taylorpro Enclosure Discussion & Design Construction Help 5 09-19-2010 09:23 PM
birch wood Anton Miller General Car Audio Discussion & Questions 45 09-17-2010 06:30 PM
birch box mrbashful210 Enclosure Discussion & Design Construction Help 10 03-20-2010 05:50 PM
MDF v.s. Birch splvictim20 Enclosure Discussion & Design Construction Help 64 01-21-2010 08:10 PM
