50s From The Trunk: 2 Z v.5 15s & Taramps HD15k - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Car Audio Help & Discussion > Car Audio Videos
Car Audio Videos Post all your car audio videos here.
Old 08-13-2017, 04:13 PM
PHATBOi's Avatar
0/11 ssssss829
Default 50s From The Trunk: 2 Z v.5 15s & Taramps HD15k
Been a while since I posted, so here's an update vid of where my build is at. 2 Sundown Z v.5 15s custom built by Brian Chamberlain at Sundown. They have SPL cones, X v.2 spider packs and 8 layer D1 EMF coils. Running on a Taramps HD15000 at 1 ohm rising to 3.8 clamping 6k. Amp is fed by a JY Power 80ah Lithium and a Custom Electric Services 340 alt.
Enclosure is a 2:1 4th rear deck blow thru built by my teammates Joel Walker and Phyllip Coleman at Soundpressure Designs. It's tuned to 42 and has 112 square inches of port area.
Burping a 152.4 at 30hz on the glass with driver's door open. Holding the current ISPLL Subsonic Suicide Trunk 2 world record 151 2 min average at 28hz. Still have work to do in the box, another power run front to back and upgrade the dual inputs on the amp to triples. There's a 54 in it, just got to find it.
https://youtu.be/IeLuPPi8TXM
Team Heavyweight
Old 08-13-2017, 05:53 PM
0/11 ssssss543
Have you tried burping a .25ohm your electrical should handle a burp and the amp should too just dont try playing music. That or add another hd15k and wire each to .5 they should take that on music.
Old 08-13-2017, 06:05 PM
PHATBOi's Avatar
0/11 ssssss829
Honestly only like to meter how I daily. Just don't like to claim a number I only did one time by changing something in the setup. I have considered running 2 amps at .5, but it would be the Taramps Bass 8 or 12k if I did. They are .5 stable. As of now, if the work inside the box and the electrical upgrades don't get me where I want to be, that is the plan. Either go back to a Korean 10k-ish amp at .25 or do the 2 Bass 8 or 12k at .5 per sub.
Team Heavyweight
The Following User Says Thank You to PHATBOi For This Useful Post:
IBleedMusick (08-15-2017)
Old 08-14-2017, 07:14 AM
0/11 sssss1117
Nice man looks clean and moving a ton of air. Also like that you put up info and gave credit. I wish I can do a 4th but trunk is small even literally taking up all the trunk I got only 8cu.ft after displacement but what's the ported chamber volume or box dimensions to see how close or far am I from a decent 4th
Old 08-15-2017, 07:39 AM
PHATBOi's Avatar
0/11 ssssss829
My box is 9 cubes net, lol. 3 sealed to 6 ported. The trunks on these Vic's are HUGE!!
Team Heavyweight
Old 08-15-2017, 08:13 AM
doug118's Avatar
0/11 sssss4674
My car is only 7.5 cubes net and I have 2 15's in there. It's not crushing numbers but I only have 5kw going to it and it sounds incredible. Within a DB from 28-36hz
Old 08-15-2017, 11:35 AM
enemyofsilence's Avatar
0/11 ssssss407
Feedback Score: 21 reviews
No kidding, that's a big box! The most room I can get in my altima is a little over 7.5 cubes. Maybe I can squeeze 2 12s in a 4th with this space lol
Team Bass-Hz
Old 08-15-2017, 11:39 AM
0/11 sssss1117
4th order? I was kinda lucky with this trunk 9.8 gross and 8.2 net
Old 08-15-2017, 11:45 AM
0/11 sssss1117
Well I did some number checking and I have a bit more length between the sub and the rear seats and being that the sub will be in the enclosure I can do 3 sealed and 6 port with bracing with external port in the rear deck aswell just would have to graph it, so gotta get a computer and load up bbp6 and check
The Following User Says Thank You to SPL Addict For This Useful Post:
PHATBOi (08-15-2017)
Old 08-15-2017, 03:27 PM
IBleedMusick's Avatar
0/11 ssssss424
Dope! I also like the fact that you said you won't claim a score you can't pull all the time. Very dope build I've always thought about buying a Vic just for music. They just seem like they'll get loud.
The Following User Says Thank You to IBleedMusick For This Useful Post:
Mint Taramps HD15k djscrubb Mono Amplifiers 11 02-10-2017 11:35 PM
2 15s in a trunk massivespl Car Audio Videos 0 03-20-2016 06:19 PM
2 15s blow through trunk joshy629 General Car Audio Discussion & Questions 15 10-21-2012 12:58 AM
two 15s in a trunk? Zooook (DC) 61 07-23-2011 12:34 AM
2 15s in trunk 20Hz_And_Below General Car Audio Discussion & Questions 3 12-20-2010 05:53 AM
