Here is a vid I made of me clamping my SD16KD on daily and burp impedances. Now remember everything on the HU and Amp is at 0 for a flat burp.
http://www.youtube.com/watch?v=A4M0N2TxJ6I
Amp starting at 4 ohms with a 60 hz burp. Settings on the HU and Amp are at 0
250.2 AC Volts x 23.6 AC Amps = 5,904.72 Watts
250.2 AC Volts / 23.6 AC Amps = 10.6 ohms
Voltage dropping to 16.6 volts
http://www.youtube.com/watch?v=-zfzPA9094A
Amp starting at 1 ohm with a 60 hz burp. Settings on the HU and Amp are at 0
188.6 AC Volts x 73.2 AC Amps = 13,805.52 Watts
188.6 AC Volts / 73.2 AC Amps = 2.57 ohms
Voltage dropping to 15.2 volts
This is all off of 6 Kinetik 16V batteries, the back bank. Vehicle is not running
