ATTN: Coleman @ Audio Technix - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > CT Sounds
Old 12-20-2012, 06:06 PM
Never Finished
0/11 sssssss97
Default ATTN: Coleman @ Audio Technix
Power cable question
Old 12-20-2012, 06:35 PM
silvercookie's Avatar
0/11 sssss1945
Are you kidding me dude? Why didnt you just post that in here?
And to answer your question, the CCA is the cheapest because it is aluminum coated in copper, not fully copper.
The OFC is the most expensive because it is 99.99% copper and it wont rust and degrade, also it transfers current the best and at the lowest temperature.
The 2nd one, the Oversized tinned 30% copper is more expensive than the CCA because it has 500-600 more strands of wire, and has more copper content than the CCA.
It all really comes down to how much you want to spend, and what kind of setup you are going to be running.
The Following User Says Thank You to silvercookie For This Useful Post:
cthedinger (12-20-2012)
Old 12-20-2012, 06:55 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
The over sized wire incorperates 10-15% actual copper wire IIRC.
Old 12-20-2012, 07:04 PM
cthedinger's Avatar
0/11 sssss1089
We have 3 different kinds of 0GA.
We have the cheapest option which is CCA. 4704 strands - Rated at 250A @ 20' -10% copper 90% aluminum.
Second is the Oversized 0GA. 5292 Strands - Rated at 300A @ 20' - 30% Copper 70% Aluminum - Silver Tinned to help prevent corrosion. This is the best alternative if you do not have the budget for full OFC but full OFC is always recommended as the first choice.
Third is the OFC. 4704 Strands - Rated at [email protected] 20' - 99.96% Pure Copper - Silver Tinned to help prevent corrosion. This is the best and highest quality option. If you are looking to get the most out of your system OFC is the way to go.
Aluminum is cheaper than Copper so the more aluminum the cheaper the wire.
If you have any questions PM me or
The Following User Says Thank You to cthedinger For This Useful Post:
Wood. (01-05-2013)
Thank you Audio Technix djscrubb CT Sounds 3 08-23-2012 02:13 PM
Thanks Audio Technix skartisu CT Sounds 0 07-17-2012 01:55 PM
Where is Audio Technix? oslouie General Car Audio Discussion & Questions 4 05-04-2011 04:05 PM
Unboxing - Audio Technix, Atmos Audio and Crescendo 5500d Bryan Car Audio Videos 4 04-12-2011 11:15 PM
