125.4 getting hot - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > CT Sounds
Old 09-27-2013, 04:58 PM
black pearl's Avatar
#AINTLOUD
0/11 sssssss22
Default 125.4 getting hot
just had all my front end wired up to my 125.4 and its getting pretty hot after just a few minutes. channels 1 and 2 are at 2ohm stereo (focal components in door and infinity components in kick panels) and 3 and 4 are just running 6.5 focal coaxials in the rear doors
Old 09-27-2013, 05:01 PM
thevic24's Avatar
Death from afar...
0/11 sssssss72
Can you post a pic of your settings on the amp and of the overall install?
Old 09-27-2013, 05:19 PM
#AINTLOUD
0/11 sssssss22
the install was done by my cousin (mepc advanced installer for 25 years)
Old 09-27-2013, 05:39 PM
thevic24's Avatar
Death from afar...
0/11 sssssss72
Good pics. Its hard to tell but how high are your gains turned up and judging by the hi-pass setting, I assume you are not using the bass boost correct?
Check to make sure your power and grounds at the amp are tight and also the ground where it is grounded to the car/truck.
Keep in mind that this amp is a class a/b so it will run hot. Even more so with the 2 ohm load on the front ch.
How hot is it actually? Can you still touch it and keep your hand on it? I take it that it has not gone into thermal protect?
To give you an idea, I have an old Crossfire CFA HC30 bridged running at 1ohm(in hi-current mode) and after a bit, it gets quite hot.
Just the nature of some amps.
Old 09-27-2013, 05:45 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
so you have two different set of components, with two different sets of passive crossovers, wired together in parallel on each one of your front channels...? That could be your problem....
-Youtube Channel
Old 09-27-2013, 05:46 PM
#AINTLOUD
0/11 sssssss22
yeah no bass, waiting for my 2500.1 to get here for the bass
I have 2 D680 batteries about 1 foot from the amp that the amp is powered by and they are grounded to the frame by a 3/8's bolt welded to the frame (2010 Tahoe) that's what you see on the right side of the first pic
I can still touch it but its good and warm but no its not going into thermal. were its at its not getting a lot of air to it, I may move it over about a foot and get it away from the seat mount (under the rear seat in the Tahoe)
Old 09-27-2013, 05:52 PM
#AINTLOUD
0/11 sssssss22
what will that do, have 2 different sets of crossovers
I did not do the wiring so im not sure how they are hooked up, but it that what the pics show then yeah, I have a focal component set in the front doors then got a deal on a set of unopened infinity kappa perfect 6.1's ($100) so I put them in q-logic kick panels.
iv been into stereo and box building a long time myself but I have never really dealt with front end/ highs and mids.
Old 09-27-2013, 06:24 PM
0/11 sssss1181
My mids and Highs amp always runs a little hot. One thing I cant quite tell but may be worth looking into is your speaker wire gauge. It looks a lil thin to me.
The Following User Says Thank You to jfoodstamp For This Useful Post:
Crunk (09-28-2013)
Old 09-27-2013, 06:38 PM
0/11 ssssss298
Probably a bad ground
Old 09-27-2013, 06:41 PM
Andrew2944r's Avatar
0/11 sssss1226
Nature of most class A/B amps @ 2 ohm.
NS-1 getting hot jmkanek (Sundown Audio) 250 10-25-2012 09:04 PM
How hot is it? 2000LaDe Off Topic Chat 82 07-25-2011 12:45 PM
125' Spools of Tsunami 4 Gauge $125 shipped!!! scottiej Wiring, Electrical & Other Installation Equipment 57 09-27-2010 08:39 PM
Hot Rods N Hot Bods at The Mens Club ~ CHARLOTTE NC ~ 11-16-2008 CACO's Car Show Bot Car Show Feeds 0 11-09-2008 02:10 AM
Hot Rods N Hot Bods 600.00 CASH PAY OUTS ~ CHARLOTTE NC ~ 10-25-2008 CACO's Car Show Bot Car Show Feeds 0 10-13-2008 02:01 AM
