Bass knob issue - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > CT Sounds
Old 11-14-2013, 03:49 PM
0/11 ssssss352
Default Bass knob issue
I need to know how your clipping light is on the bass knob.I can't find the manual. I currently have the 7000.1 and with a very little turn of the knob the clipping light starts blinking red. It is consistent on almost every song I play, and all my songs have been checked for clipping and are all clean.
When I continue to turn bass knob up it gets lots louder, like almost two to three times louder? I have run several amps over many years and just replaced two bc3500's which had clipping lights and never had this issue with the clip light until obviously the amp was almost at peak power and didn't get much louder.
Both amp setups were with same head-unit, RCA's Voltage holds a very steady 14 volts with the clip light on, but if I turn it up it still never goes below 13 volts Wang chunging.
Does the light have to stay steady red, does it change to another color, is it possible something is wrong with knob I am going to check soon with DD-1, but sold mine months ago. I know my radio doesn't send a clipped signal until 47 out of 50, yet at 30 the bass knob light starts blinking hard and if I go to 33 most songs will go solid.
J
Old 12-04-2013, 09:01 PM
ENVI3D ONE's Avatar
Never Satisfied
0/11 sssss2103
Feedback Score: 22 reviews
I hooked mine up to make sure it works and mine does the same thing. I know other ppl that had tested the amp also said the light comes on really early.
IMO it kinda defeats the purpose of having a clip light if it's no where near accurate
Old 12-04-2013, 09:14 PM
G00burr's Avatar
0/11 ssssss591
i'll second that.
Old 12-04-2013, 11:19 PM
0/11 ssssss352
Exactly...its almost always on even when I turn knob down??
The Following User Says Thank You to vetkilr For This Useful Post:
IS300IAdeathRow (12-05-2013)
Old 12-04-2013, 11:28 PM
0/11 ssssss443
Its not accurate.. I compared the bass knob accuracy to an oscope
Old 12-05-2013, 03:47 PM
cthedinger's Avatar
0/11 sssss1089
Right now from what we have seen this is only an issue with the 7000.1 and we are working on getting it fixed, when we fix it we will send everyone with a 7000.1 a new bass knob.
However many companies clipping indicators are off, it is more of a reference light. We suggest you always set you amp with an O-Scope or a DD-1.
If you have any questions PM me or
The Following User Says Thank You to cthedinger For This Useful Post:
vetkilr (12-05-2013)
Old 12-05-2013, 03:50 PM
SPL Distribution Owner
0/11 sssss2983
Clipping lights are not and cannot be made to be accurate when playing dynamic material.
A clipping light is only accurate on a sine wave.
The Following 2 Users Say Thank You to shizzzon For This Useful Post:
FocusOn20s (12-07-2013), joe98chevy (12-05-2013)
Old 12-05-2013, 07:13 PM
0/11 ssssss352
Unless you have a 7000.1 or have seen this issue in person, you need not respond. It is pretty ridicoulous actually.
Can't wait for the fix Coleman
Old 12-05-2013, 07:25 PM
chaveSS96's Avatar
0/11 ssssss181
I've noticed that on my knob that came with my 1400.1.. Also the volt meter isn't as accurate as I would have thought. I have taken readings directly on the amp with a dmm and it's about 0.4v off.. anyone else?
Sent from my SM-N900V using Tapatalk
Old 12-05-2013, 07:29 PM
0/11 sssss2983
That wasn't directed toward the 7,000w amp, just stating a fact about clipping indicators on dynamic source material.
Sorry for sharing facts.
The Following User Says Thank You to shizzzon For This Useful Post:
bass gain knob or bass boost knob??? spl_robb General Car Audio Discussion & Questions 4 04-06-2013 11:29 PM
Help with bass knob issue Colbyjack (Sundown Audio) 8 01-18-2013 07:55 PM
Issue with Bass Knob shogen (Crescendo) 22 04-09-2012 11:04 PM
bass knob issue i think. fox_racin4 General Car Audio Discussion & Questions 4 05-24-2011 01:13 PM
Bass knob issue mythyone General Car Audio Discussion & Questions 10 02-14-2010 04:06 PM
