New CT Sounds 3-Way Component Sets! - Car Audio Classifieds!
Go Back   Car Audio Classifieds! > Vendors > CT Sounds
Old 03-02-2018, 09:10 AM
cthedinger's Avatar
0/11 sssss1089
Default New CT Sounds 3-Way Component Sets!
CT Sounds 3-Way Component Sets are now available on Pre-Order!
https://www.ctsounds.com/products/ca...nt-speaker-set
Pre-order yours now!
RETAIL $799.99
THIS IS A PRE-ORDER, ORDER NOW AND SAVE BIG!
ESTIMATED SHIPPING DATE: May 15, 2018
DO NOT ORDER IF YOU ARE NOT WILLING TO PATIENTLY WAIT FOR THE ITEMS TO ARRIVE. ESTIMATED SHIPPING DATES ARE AN ESTIMATE AND ARE SUBJECT TO CHANGE.
NO REFUNDS ON PRE-ORDERS
Check out CT Sound's hottest full-range component set- the Meso 6.5 Inch 3-Way Full Range Component Speaker set. This is a complete full-range speaker set that includes woofers, mid-ranges, tweeters, crossover boxes with accessories for mounting; like one complete set one would need in his vehicle. This set covers quality audio within your vehicle and covers a lot of mid-bass as well. And about going loud without distortion, this set is undoubtedly a superb one.
WHATS IN THE BOX:
2 x Meso 6.5" component Speakers
2 x Meso 3.5" Midrange Speakers
2 x 25mm CNC Silk Dome Tweeters
2 x ABS boxed crossover
FEATURES:
Fiberglass cone & NBR surround for rich audio tones
PC+NOMEX spider with 6mm top plate and 5mm back plate
Spring terminals on each woofer for easy & quick connectivity
Black colored 1.4" (dia) voice coil
Incorporates Y30 ferrite and neo magnets
Each 25mm silk-dome tweeter is covered with silver chrome plated face grille and is attached with Copper Clad Aluminium Wire pair (CCAW)
Crossover circuit box has dark clear top cover with CT Sounds logo printed on top of it
Cast aluminium basket with black powder texture paint
Includes face grilles for extra protection
TECHNICAL SPECIFICATIONS:
Speaker size: 6.5"
Speaker type: Component
System total power: 150W (RMS) | 300W (MAX)
6.5" Woofer:
Rated power per speaker: 60W (RMS) | 120W (MAX)
Rated power per speaker pair: 120W (RMS) | 240W (MAX)
Rated impedance: 4Ω (Ohms)
Output SPL (@1w/1m): 89dB
Resonant frequency: 65Hz
Frequency response (@SPL -10dB): 50Hz ~ 20kHz
Magnet weight: 21 Oz
Magnet type: Y30 ferrite
3" Mid-range Woofer:
Rated power per speaker: 30W (RMS) | 60W (MAX)
Rated power per speaker pair: 60W (RMS) | 120W (MAX)
Frequency response (@SPL -10dB): 30Hz ~ 15kHz
Magnet weight: 1.9 Oz
Magnet type: Neo
Tweeter:
Rated power per tweeter: 25W (RMS) | 50W (MAX)
Rated power per speaker pair: 50W (RMS) | 100W (MAX)
Output SPL (@1w/1m): 90dB
Frequency response: 1.5kHz ~ 20kHz
Tweeter size (dia): 1"
Tweeter type: Silk-dome with metal mesh & face grille
Magnet type: Neo
Crossover:
Crossover circuit: 4μF capacitor/100V
Crossover point: 3.5kHz
Filter for woofer: 6dB
Filter for tweeter: 12dB
MOUNTING / INSTALLATION PARAMETERS:
6.5" Woofer:
Cutout diameter: 5.8" / 148mm
Outer diameter: 6.95" / 177mm
Mounting depth: 2.9" / 74mm
Cutout diameter: 2.82" / 72mm
Outer diameter: 3.88" / 99mm
Mounting depth: 1.59" / 40mm
Tweeter:
Cutout diameter: 1.61" / 41mm
Outer diameter: 2.17" / 55mm
Mounting depth: 0.61" / 16mm
If you have any questions PM me or
CT Sounds Component and Coax Sets cthedinger CT Sounds 6 10-01-2013 10:29 PM
New component sets dagodpere (Crescendo) 2 06-11-2012 05:02 PM
Component Sets??? shogen (Crescendo) 24 01-18-2012 09:08 PM
Component Sets? MikeTeeXPO General Car Audio Discussion & Questions 1 01-15-2012 02:12 PM
FS: Component Sets and EQ MopaRBumpiN Car Audio Packages 7 12-17-2010 11:14 AM
