DC 9K - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 10-01-2011, 12:01 AM
0/11 ssssss766
Default DC 9K
OK guys i need some help.
i have a pair of dc 9ks and im not sure what to do as far as batts
12v vs 16v batts?>...
i already have 2 alts on my truck . i can either go 12v batts and use both of my alts to charge or go with 16v batts and only use one alt to charge my 16v batts/ sub stage and the other one for my trucks 'stock electrical'
what would be\\work better for me ?....
i do not drive my truck daily
also i have 4 18'' rd super heavy weigths that are dual 1's
my plan was to wire a pair of subs to each amp for daily @ 1ohm
and strapp them @ .25 each for a total load of .5ohm for burps...
PROS AND CONS OF THE 12V AND 16V ??....
EDIT; BATTS WOULD BE xs power d3100's or d1600's/xp1000's
i need some HHEEELLPP
05 ford f-160
4 18'' dc audio level 6
2 dc 9.0ks
singer 400a
@44hz
Old 10-01-2011, 12:09 AM
toad559's Avatar
0/11 sssss1508
i say do the 16v and 12v for ur truck. im doig a 14v setup chrging at 16.8v max. single 200alt and 11 d1400. it does fine on both strp a 1ohm imo u be happier with the 16v. get like at least 10 batts. it will be fine on burpn at .25. i did that on one of my 9k with 4 batts. burped it a few times lol. i vote 12 and 16v.
Old 10-01-2011, 12:13 AM
0/11 ssssss766
that was another of my questions, would teh 9ks be able to do burps @ .25 on 16volts >?>....
'if' i do 16v i want at least 15 batts
05 ford f-160
2 dc 9.0ks
singer 400a
@44hz
Old 10-01-2011, 12:15 AM
Prohibited Sellers/Buyers
0/11 ssssss607
If its just for competing do 16v.. But did u sell all your batts?
Drive that truck daily that thing is so clean!
Old 10-01-2011, 12:38 AM
0/11 ssssss766
yeah dude , sold all my d1600's.. wanted to go 12v on the soundigital 12k ,
but since i got me a couple of 9k's idk what to do ...
i wish i could drive my truck erryday but im @ work 6 days a week
05 ford f-160
2 dc 9.0ks
singer 400a
@44hz
Old 10-01-2011, 10:48 PM
0/11 sssssss98
i do drive my burban daily, at comps its charging at 16.2v and daily at 15.6 i have 2 DC 9.0k's and im running them at .4 ohms all day everyday although on the real low (like 20hz stuff i have to be easy on the gain knob or they will protect b/c the ohm load drops to almost .4 lol)
normally i tested mine and i usually see a rise to around 1ohm per amp
i have 14 XS Power D3400's and was running on 2 singeralternator 350amps, but now have 3 400+amp alts on the way!!!
good luck bro you will love those amps!
at 16.2v we clamped almost 11k off one amp
Old 10-01-2011, 11:15 PM
AudioAnonymous's Avatar
0/11 sssss1723
I wouldn't try it.
If they are like the 5K's..... .35 on 16 volt is do-able but a little picky. I do know they will burp .25 on 12 volts though.
CACTUS SOUNDS
2006 db drag WF 3rd place 161.2 SM3-4
2007 db drag WF 1st place 163.4 SM3-4
Loudest to date 165.9 SS3-4 with borrowed equipment
2010,2011 db Drag World Finals judge.
Old 10-01-2011, 11:51 PM
0/11 sssssss98
As long as you have a good electrical system behind them they will do it, I have video proof lol look at my YouTube videos the 160.2 was a burp on a 43hz tone at 16.2 Volts... I just roll in fairly quick to resemble a straight burp, the previous owner of my 2 9ks was running them fairly hard lol 18v and .25ohm roll in burps strictly competition vehicle tho (I'm not completely forsure on that set up but rusty would know)
Old 10-01-2011, 11:57 PM
1loudyukonxl's Avatar
0/11 sssss1569
do 16v they will be fine for burps a .25
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 10-02-2011, 12:28 AM
0/11 ssssss766
yeah its looking like ill go the 16v route.
ill run them daily @ 1ohm each non strapped
and ill try .25 each strapped for burps
thanks for all the input guys
btw , batts are sooo focken expen$ive.. lol
05 ford f-160
2 dc 9.0ks
singer 400a
@44hz
