New 12k Clamp test. HATERS ENtER NOW! - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 10-13-2011, 03:50 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Default New 12k Clamp test.
I just got done testing the 12k in 2 different applications.
The first test was done in the Mini Van with 4 XL 18s and 4 D3100s starting voltage 14.2.
The second test was done in my truck with 6 Level 3 15s and 5 D1400s starting voltage 15.4.
Van results: Starting ohm load is 1 ohm bridged
30hz- 49A x 141.7v= 6943.3 watts @ 2.89 ohms
35hz- 39.89a x 144v= 5744.16 watts @ 3.6 ohms
40hz- 46.8a x 137.8v= 6449 watts @ 2.94 ohms
45hz- 47.3a x 137.4v= 6499 watts @ 2.90 ohms
12k Rated power
1 ohm bridged 12v- 8400 watts
1 ohm bridged 14.4v- 11000 watts
1 ohm bridged 16v- 13000 watts
2 ohms bridged 14.4v- 6800 watts
4 ohms bridged 14.4v- 4200 watts
8 ohms bridged 14.4v- 2400 watts
Now for all of you that hate on those results saying "Im paying for 12000 watts but im not getting it so I am going to be an ass and flame the results"
This second test was done in my truck running 6 Level 3 15s starting ohm load of .67 bridged. Voltage started at 15.4 and dropped to 12.5.
30hz- 97a x 117v= 11349w @ 1.21 ohms
35hz- 95.2a x 123v= 11710w @ 1.29 ohms
40hz- 86a x 129v= 11094w @ 1.5 ohms
45hz- 78.2a x 134v= 10478w @ 1.71 ohms
I believe this is proof for all of those that hated on my original clamp numbers that the 12k is well worth the money you pay because it does well over rated power.
The Following 2 Users Say Thank You to codyj18 For This Useful Post:
Novicaine (10-13-2011), Zooook (10-13-2011)
Old 10-13-2011, 03:56 PM
Ronmeister's Avatar
0/11 ssssss791
Yeah, finally some good clamped numbers from DC amplifiers.
Lol, I found them to be quite pitiful earlier.
Good stuff mang.
Are those peak power output numbers or where output settled?
Old 10-13-2011, 03:58 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
Gotta love the title.
Great test, when is the 9k getting clamped?
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
Old 10-13-2011, 04:00 PM
0/11 sssss1596
Good stuff mang.
These are the peak output numbers. I dont find any of the clamp tests I have done to be pitiful at all. You have to look at the rated power of an amplifier.
BOX RISE EFFECTS THE POWER YOUR AMP PUTS OUT. You can see that I have much less rise in my truck which allows me to get more power from the amp.
Old 10-13-2011, 04:11 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
Like i've explained in another thread, amps clamp ROUGHLY half when you wire them normally to their nominal rated load. All amps are like this, if you want 12k clamped then it takes a final 1 ohm load after impedance rise/reactance.
Old 10-13-2011, 04:16 PM
BKNIGHTS's Avatar
0/11 sssss2949
Feedback Score: 61 reviews
Do you think its not as risky to wire below 1ohm as its made out to be?
Old 10-13-2011, 04:18 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
hating
you probably wont like me
Old 10-13-2011, 04:23 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Perfect perfect says he's wiring his dc 12k at .125 per channel iirc (defently not advised)... I wonder what he'd clamp if he had more electrical.
Originally Posted by upzaw2000 View Post
hating
You would wouldn't you
2003 BMW 330I
Old 10-13-2011, 04:30 PM
RE_XXX's Avatar
0/11 sssss3182
Got much lower out of my buddies 12k.....starting at 15.2 i believe... 68xx @ 1.8 ohms
So all these DC 12k numbers arent matching up........ something is quite interesting
here.....
Either someone is full of it, being as I am the only NON DC PARTY that has done a test on it.
Looking at those numbers, its not a good 12 volt amp for its said power...but cant take over 16 volts....
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
Old 10-13-2011, 04:34 PM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
here.....
What was his voltage drop? Cause 6,[email protected] (you got nearly 2ohm) it's rated at 2 ohms bridged 14.4v- 6800 watts
2003 BMW 330I
Clamp Test! DC5K vs. Sundown 4500 vs.AB500.1 twistedchild420 Car Audio Videos 339 01-27-2012 05:09 AM
Updated SA-12 QC Test w/ Power Clamp ! sundownz (Sundown Audio) 12 01-14-2012 02:12 PM
DC 5k and 12k clamp results codyj18 (DC) 22 09-18-2011 12:15 AM
AQ3500.1 Clamp test csu87 General Car Audio Discussion & Questions 80 12-06-2010 02:38 PM
Performing Uniform Clamp Test on all Sundown Class-D Amps sundownz (Sundown Audio) 10 07-26-2009 11:09 PM
