Lvl5's in a Magnum? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 10-24-2011, 03:00 PM
TeamOSC's Avatar
0/11 ssssss207
Default Lvl5's in a Magnum?
I picked up some Lvl5 18's the other day and figured I'd give them a try.The only problem I'm having is the magnum,there just don't seem to be enough room left over after amps/batts for the pair,so my question is would I be better off running 1 in a 5.5-6 cube sub up port back,or 2 in a 10 cube enclosure subs/port up?(no room for anything bigger) This will be a daily/demo setup run off a XXX10k w/solid electrical. Also,will not do a wall,keeping the rear seat so a wall in this car would be pointless.
Team O.S.C.
Team XS Power
Old 10-25-2011, 10:23 AM
DC98hoe's Avatar
Doing 156s below the seat
0/11 sssss1372
Do 1 in 5cubes with 16-20 sqin of port. Sub up port back leave at least 7in from the back so port can breath
98 tahoe 4-team ascendant 18s ,2-Flatline 9.5s 18 v --singer 320 hairpins-4th order 160dbs
Old 10-25-2011, 11:28 AM
TeamOSC's Avatar
0/11 ssssss207
That's what I wanted to hear Tried one in my old AQ box that was real close to those specs but there was only a db difference between the two subs.I'll try dopping down to 5 cubes and open up the port a bit and see what I can get out of it.
Team O.S.C.
Team XS Power
Old 10-25-2011, 01:01 PM
0/11 ssssss255
what are you doing with the extra DC LVL 5?
Old 10-25-2011, 01:17 PM
TeamOSC's Avatar
0/11 ssssss207
I'm planning on getting 2 more and running them in my spl van next year if they work out.
Team O.S.C.
Team XS Power
Old 10-25-2011, 02:04 PM
0/11 ssssss255
that sounds rather epic
4th order for 2 18" lvl5's alexis8284 Enclosure Discussion & Design Construction Help 4 07-04-2011 07:51 PM
best amp for 2 18"dc lvl5's? alexis8284 General Car Audio Discussion & Questions 12 05-31-2011 09:50 PM
magnum speaker size? Ryan1126 General Car Audio Discussion & Questions 4 04-17-2011 07:32 PM
fs: Two BNIB DC Team LVL5's in any size! ssackett Speaker Accessories & Parts 19 02-14-2011 02:00 PM
my magnum willie3719 Build Logs 24 10-29-2010 06:39 PM
