dc 3.5k at .5 - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 11-08-2011, 03:57 AM
98Expo's Avatar
0/11 sssss1929
Feedback Score: 23 reviews
Default dc 3.5k at .5
I am going to be running my 3.5k's strapped on 4 hdc18s at 2 ohm, but was wondering how much more power could I get running @ .5 ohm? And would a 270 alt, 3 xs 3100's and a 6500 be enough electrical to run like that or should I just stick with 2 ohms strapped? Just for daily, no comps
2 FI bl 18's walled in 2012 scion xb
Old 11-08-2011, 08:34 AM
0/11 sssss1564
Your electrical sounds good as long as you have big 3, and multiple runs of 1/0. Im running my 3.5K @0.5 ohm and my 18" XLs are HAMMERIN' ... I have a Mechman 200 amp alt and 1 group 34 up front and one group 27 in back and voltage stays 12.6-13.4 depending on the note. Im about to add another group 27.
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Old 11-08-2011, 08:46 AM
got160s?'s Avatar
0/11 ssss13630
You'd gain quite a bit of power depending on what your reactive, etc.
My guess is you should be able to handle it like brandon said and you would be adding a little more then doubling your power
Vehicle: 1999 Chevy Suburban AKA The Bammin' Beast
Battery: 25 XS Power XP1000's
Sub Amp: 3 DC 9k's
Sub Stage: 18 DC Lvl 4 M2 12's in a Nasty 4th Order
Subscribe now! Prizes will be given away for every 1000 subscribers!
Old 11-08-2011, 01:40 PM
98Expo's Avatar
0/11 sssss1929
i am in process of doing the big 3, my alt will be here thursday, and I have all the batts now, I guess if voltage drops I could add another battery if needed, and i have 2 runs of + and 2 runs of - now
Old 11-08-2011, 04:53 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
I wouldnt not strap at .5 ohm. You will void you warranty by doing this and will put alot of extra stress on the amps by running them at .25 per amp. You can run at 1 ohm strapped but your warranty will still be void by running under 1 ohm per amp.
Old 11-08-2011, 05:05 PM
0/11 sssss2298
Feedback Score: 54 reviews
My guess is they will protect regardless of how good your electrical is. .25 per amp (.5 strapped ) is not worth the extra stress and heat you will create vs running at 2 ohms strapped. Maybe for burps but NEVER AT ALL should amps be ran that low unless designed to on a daily system.
Old 11-08-2011, 06:17 PM
98Expo's Avatar
0/11 sssss1929
Yeah I decided not to, I was thinking each amp would b .5 before, not .25. I'm just strapping at 2ohm ,1 ohm per amp
Old 11-09-2011, 09:26 AM
MECHMAN's Avatar
0/11 sssss1142
That's a lot of load for one alternator, but with proper batteries it will work. Watch the voltage and if it starts to drop too far after playing a while pick up the engine speed(if idling) and lay off the system for a couple minutes to let the batteries recover.
I have seen people do more wattage with less alternator so I think you will be fine.
If you need more power we do have our new hybrid that's going into production shortly that has done [email protected] in my Crown Vic Police Interceptor and is now being built to fit GM too.
Old 11-09-2011, 01:28 PM
98Expo's Avatar
0/11 sssss1929
im just sticking with 2 ohms strapped (1 ohm per amp). But Later down the road I may run a dual setup or step up to the bigger alt
