wiring lvl4 15"s - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 12-03-2011, 10:54 AM
0/11 sssssss24
Default wiring lvl4 15"s
ok i just bought 2 15" lvl4s and i was wondering how do i tell if they were dual 2 or dual 4ohm?
sorry for the noob question but im new to this stuff.. slowly learning!
Old 12-03-2011, 11:27 AM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
really the only way to tell is to test them with voltmeter that has the ability to measure ohms.
Old 12-03-2011, 11:43 AM
btsteinb's Avatar
0/11 sssss3573
Feedback Score: 30 reviews
get a digital multimeter.
put the prongs or clips on the wires for the sub and turn the multi to ohms
Old 12-03-2011, 01:03 PM
0/11 sssssss24
awesome thanks for the replys.
ok so does it matter which terminals i use on the sub? its a dual voicecoil, so should i wire it like i was going to hook it up to an amp and then test it or am i over complicating it?
Old 12-03-2011, 01:49 PM
caloriu's Avatar
0/11 sssss2863
when testing ohm polarity does not matter but i always test them properly red to positive black to neg.
as for wiring you need to know what ohm sub you have so you can wire it properly according to the amp you are going to use.
for example, if its a dual 2 ohm you can wire to get 2 or 4 ohm load dipending on what amp you have most amps these days are 1 ohm stable some are only 2 ohm stable .
also are you using 1 amp for each sub or 1 amp per sub?
when you are building a system alot of info is needed the better you prepare for the install the smoother and more reliable it will be .
for example what kind of power on single or dual amps? alt, wires, power/ground, any extra batt?
not trying to confuse you but i see people trying to run a 3k amp on stock electrical on 4 guage wire.
also level 4 subs is not an entry level so keep in mind each sub takes 1000 watts rms and thats propably the least amount of power to get some kind of decent sound out of them each .
Old 12-03-2011, 02:23 PM
0/11 sssssss24
ok thanks for the advice. I guess I should of listed all the details first.
I just bought these subs off c-list with an AQ 2200 amp. I asked the kid if they were dual 2 or 4 and he was unsure. He said the guy he bought them from hooked them up for him. I am assuming they are dual 4 so they could be wired to 1ohm, but I want to be sure.
My truck is currently wired with 1/0 kicker wire. Im going to do a big 3 up grade on my stock alt. Also I was told I could run up to 3k on my stock alt but should get a 2nd battery. I believe my alt is 170amp or so?
I still have to build a box and everything else first, I am just seeing if this amp sub combo will go good together.
Old 12-03-2011, 03:01 PM
caloriu's Avatar
0/11 sssss2863
once you do the big 3 and extra batt that set up should work just make sure you dont drop below 13 v when car is running and i would test the extra battery before starting the car to make sure it rests at 12.6 minimum.
also you already made a mistake when buying subs off of cl unless you know the guy personally you should always check the coils .
i know checking the coils is not the best way to see if they are fully working subs but really with out a box and amp installed its the only real test you can do.
start by checking each of the 2 coils per sub and see what you have so no need for guessing just because the previous guy did something does not mean its always the right way.
i hooked up a friends amp at 1/4 ohm before rise with monster electrical and no issues is this recomended depends who you ask .again just becuase we did it does not mean its right but was fun lol. and no the amp did not blow up and until today its still playing every day on music.
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
The Level 4s would either be D1 or D2, they are not offered with a D4 coil.
Old 12-03-2011, 04:00 PM
0/11 sssssss24
so when i test the coils they should should read 1 ohm for d1?
Old 12-04-2011, 03:50 AM
Crazy4bass's Avatar
Das Wagen. Do Werk.
0/11 sssss1973
No, they should read .5 or 2 ohms each woofer for d1.
2 15" lvl4 dc zrated12 Enclosure Discussion & Design Construction Help 1 12-02-2011 02:16 PM
18" dc lvl4 xl d2 jamiebassman 18" Subwoofers 0 06-14-2011 08:13 PM
Dc lvl4. 10". silveradothump 10" Subwoofers 7 04-07-2011 12:00 PM
15" DC LVL4 d2 doylerules826 15" Subwoofers 32 11-17-2010 01:09 PM
