How to drill hole in surround? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 12-06-2011, 10:21 PM
0/11 sssssss55
Default How to drill hole in surround?
I have a level 5 with the reinforced surround - but it doesn't have any screw holes in it. I tried drilling though - but the surround gets wrapped around the bit. An exacto knife doesn't seem to cut through the threads either.
Note that I am using t-nuts.
Ideas?
Old 12-06-2011, 10:25 PM
Supergumby5000's Avatar
0/11 ssssss642
Ideas?
wait, what?
Surround or gasket?
Old 12-06-2011, 10:32 PM
Ronmeister's Avatar
0/11 ssssss791
I've just gone in with a small brad nail and poked it through. The tiny incision the brad nail made was enough to let the screw through and keep it from twisting up on it.
Old 12-06-2011, 10:33 PM
Ronmeister's Avatar
0/11 ssssss791
You can also try a smaller bit on the drill, then high RPMs and low pressure. Let the sharpness of the bit do the work, and take away the material, don't necessarily force it through.
Old 12-06-2011, 10:38 PM
Ronmeister's Avatar
0/11 ssssss791
Originally Posted by Supergumby5000 View Post
wait, what?
Surround or gasket?
Surround.
His doesn't have the screwholes punched out from the manufacturer
Old 12-06-2011, 10:42 PM
0/11 ssss31258
The easy way is to run the drill in reverse. it will not grab the material or netting. it will spread the netting.
I suggest 3/16" bit.
Also, you'll need to run the drill a little extra after you are through..to make sure the hole is wide enough the screw won't grab the material.
Snowdrifter (12-07-2011)
Old 12-06-2011, 11:05 PM
finbar's Avatar
0/11 sssssss23
Old 12-07-2011, 01:22 AM
0/11 sssssss55
You=saviour right now haha
Thanks!!
Old 12-07-2011, 04:09 AM
0/11 sssss2264
Feedback Score: 33 reviews
Red hot nail, and some thick thick gloves
Sent from my LG-MS910 using Tapatalk
pretty sure the lms coil just aids in some woogey boogy shitt called SQ
Whats prototype about an off the shelf design in an off the shelf casing?
Old 12-07-2011, 04:48 AM
0/11 ssss31258
sounds like a soldering pencil. I hadn't though of that.... that may be the "hot" solution.
someone needs to try burning holes with a soldering pencil and report back
Ridgid 18V drill mbdblue Miscellaneous Stuff For Sale 1 04-09-2011 05:24 PM
Small hole in foam surround johnboss General Car Audio Discussion & Questions 6 08-22-2010 02:18 PM
dewalt cordless 14.4v drill tankglh21 Miscellaneous Stuff For Sale 0 07-06-2009 02:39 AM
WTB: Drill / Router s Beatz Wanting to Buy (WTB) 0 02-05-2009 11:29 PM
Got new drill at Walmart Patrick Simmons Off Topic Chat 20 09-05-2008 08:35 PM
