How low can i go? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 12-22-2011, 03:24 AM
0/11 ssssss227
Question How low can i go?
I have a 2.0k and I was thinking of getting an xs power d5100 in the back of my car and I ha e an xs power d3400 under the hood and a 280amp alt...how low can I safely go for daily? (Before rise of course)
Old 12-22-2011, 03:27 AM
Radioactiv's Avatar
0/11 sssss1311
I run a 3k on a rebuilt 200amp and 2 34s. Around 3/4 gain I'll sit around 12.5 at idle.
You would be safe with another battery easily.
Ranger Build
Old 12-22-2011, 03:44 AM
0/11 ssssss227
Oh poop I meant for ohm load...sorry, my bad
Old 12-22-2011, 03:46 AM
0/11 ssssss639
I think he is referring to impedence. I say just test test test. See what you drop to at .5 nominal. Because you should be more than ok at 1.
Sent from my DROIDX using Tapatalk
Old 12-22-2011, 03:48 AM
Radioactiv's Avatar
0/11 sssss1311
Ah my mistake also. You would really just have to test it. Some amps have different efficiency at lower ohm loads.
Ranger Build
Old 12-22-2011, 03:53 AM
0/11 ssssss227
Voltage ain't too big of a deal to me lol I'm Jw how low of an impedence u guys think I can do for daily....like plan for an hour or so of straight beating the hell outta everything ;P
Old 12-22-2011, 12:35 PM
0/11 ssssss227
Bueller?
Old 12-22-2011, 02:34 PM
bassbear007's Avatar
0/11 ssssss745
with that elec. you should have no problem running at .5ohm
2002 s-10 ext cab
Kenwood hu
Old 12-23-2011, 12:52 AM
thorshammer's Avatar
Loyal Member
0/11 sssss2315
The amp has shown to do quite well at .5 by those who have tried it. Haveing said that you lose warranty wired below 1ohm.
Team DefJ
First Trunk in Iasca IDBL Bassboxing History to Average a 150+ after all 3 rds.
152.2 Legal Pr. of 10's out of a Trunk
153.1 Certified DbDrag Pr of 12's
Ported and Powered by Psychoacoustics
Old 12-23-2011, 12:58 AM
0/11 ssssss227
I dnt have a warranty because I nought it from someone else...but if it can handle it for daily then thank u guys I I was thinking 2 runs of 1/0....one positive, one negative... Sound good besides the grounds up front??
how low is too low for a sundown amp? scfaust General Car Audio Discussion & Questions 11 07-25-2011 05:57 PM
BNIB Treo rsx 1900. for the LOW LOW snoopysnooper Mono Amplifiers 8 05-04-2010 04:53 PM
[TRADED] 8" resonant engineering re8 on the low low snoopysnooper 8" Subwoofers 17 12-14-2009 02:31 PM
low really low streetbass cab thecat666 Enclosure Discussion & Design Construction Help 0 11-25-2009 11:30 PM
Low coolant warning light - Its not low tho..??? westman995 General Automotive Chat 9 11-24-2009 09:45 PM
