How much abuse can a 15" lvl4xl take? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 05-31-2009, 02:12 PM
Supergumby5000's Avatar
0/11 ssssss642
Default How much abuse can a 15" lvl4xl take?
Just curious
I see that they are rated at 1500RMS. What kind of power are the 15" xl's actually taking?
Old 05-31-2009, 02:21 PM
RE_XXX's Avatar
0/11 sssss3181
install dependant. Burps or for daily?
Im sure they could take a wall socket for a few minutes
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
Old 05-31-2009, 02:22 PM
upzaw2000's Avatar
Thredz lik Ur Mom- VIRAL!
0/11 ssss14427
i know someone giving them exactly 1500 rms... i wouldnt throw too much more at them....
you probably wont like me
Old 05-31-2009, 04:23 PM
dak446's Avatar
0/11 sssss5914
really? i was under the impression the whole point of the xl thing was so they had better thermal handling....that's interesting
Old 05-31-2009, 04:49 PM
rusty has ran 2500 to a couple
Old 05-31-2009, 04:50 PM
upzaw2000's Avatar
0/11 ssss14427
ya the box is kinda big with a big port so that makes a huge difference too...
small box and small port you can throw tons of power at...
Old 05-31-2009, 04:56 PM
0/11 ssssss480
i had a box issue with my btls, the box design i had was made for them handle exactly 2k, but i was giving them a lil more and they couldn't take it for long, i wish i would of known back then it was because of the box
The Rebuild
Powerbass Xta5000.1 (check)
4 DB Drive PLW12s (check)
Box 9.1cuft @ 29hz (check)
3 dekas (2 of 3)
alternator
alpine cda 9886 (check)
10 seleniums (check)
Punch 850.2 (check)
Old 05-31-2009, 08:48 PM
RustyWCA's Avatar
DC Ring Leader
0/11 sssss1292
Wrate them at 1500 although most people I know run 2-2.5K per sub, its not nessisary though, the XL preforms great off of 1500 watts and If I used them I would probly use 1500 per sub for daily.The reason we rate them at 1500 is when you get into higher powered systems there are a lot of other factors that come into play, clean power, box size, port size, tuneing, and whatnot, all of those things can work for or against a subs power handling. Goes back to the age old car audio saying, "its all in the install"
(855)SPL-DBZZ
(855)775-3299
GET CONNECTED
Old 06-01-2009, 09:27 PM
BASS14's Avatar
0/11 sssss1086
i have mine seeing around 2700+ each daily,with no issues at all in a 8cube wall tuned to 32hz
Subs-2 15" SSA XCONs
box-Huge 4th Order BlowThrough
Deck-Kenwood KDC-X996
Amp-Cactus Sounds K5 wired at half ohm
Wireing-knukonceptz through out
Battery(s)-2 NGT Extreme NG31s project db terminals
Old 06-01-2009, 09:54 PM
scott s's Avatar
Loyal Member
0/11 sssss1311
mine are running on a sd8000.1 so they take alot of abuse. i just reconed them to 15's from 12's but the 12's took a ton of abuse, the only reason the were changed was i tore the spiders from being on 2-sd8000's
Team dc audio
sbn 23 09 stock 1 northamerican champ
sbn 23 stock 2 champ
meca 09 s4 champ
nspl suv hardcore wr holder 154.1
[SOLD]4 sale 10" RE HC, 10" lightning basket, D1.4 flatwind, 9" spiders, CF dustcap! TeamPSI (Fix My Speaker) 6 04-02-2009 04:40 PM
4 sale - 10" RE HC, 10" lightning basket, D1.4 flatwind, 9" spiders, CF dustcap! TeamPSI (Fix My Speaker) 4 03-27-2009 02:57 AM
[SOLD]4Sale - NEO 18" - Custom Painted - CF Cap - 3" D1.4 (2.75" long coil) - 1500+ r TeamPSI 18" Subwoofers 8 03-25-2009 02:32 AM
4 sale - NEO 18" - Custom Painted - CF Cap - 3" D1.4 (2.75" long coil) - 1500+ rms TeamPSI (Fix My Speaker) 11 03-25-2009 02:31 AM
Soon to be dad of twins. 18"LVL4XL!! cuseikan (DC) 38 02-15-2009 03:16 AM
