M2 level 3s on 6k? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 02-03-2012, 01:00 PM
0/11 sssss1181
Default M2 level 3s on 6k?
Now that I have your attention... I will be buying 4 m2 Level 3 15's to install into my wall in my Civic. How will these woofers like a total of 6k from a Lanzar Optidrive 6000 at .5 ohm? Can they handle the 1500 watts or so a piece or do I need to upgrade to the lvl 4 coils or just the level 4?
Old 02-03-2012, 01:05 PM
tacomaguy1's Avatar
0/11 sssss4401
only one way to find out
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
The Following User Says Thank You to tacomaguy1 For This Useful Post:
cgriffin224 (02-07-2012)
Old 02-03-2012, 01:07 PM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I think you will be just fine. Just make sure you have a few batteries.
Old 02-03-2012, 01:38 PM
newarkbeast973's Avatar
1/11 sssss7810
If its clean unclipped power, I think you'll be good. I wouldn't do it but you can try.
New build coming soon!!
Old 02-03-2012, 01:48 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
With perfectly clean, undistorted power, you will be putting the Level 3 coil and motor right at its limit. I know this because I did it. I clamped 1500w+ to the Level 3 prototypes and found 1500w to be the limit. You MUST have perfectly clean power and design the box according to the power. I would recommend 3-3.25ft3 per sub NET.
Old 02-03-2012, 04:22 PM
0/11 sssss1181
I've got 3.5 cubes net each tuned to 35hz. I guess real talk after impedence rise and my electrical i will probably be way less power than that. But I think I will at least upgrade to the lvl 4 coils
Old 02-03-2012, 04:29 PM
0/11 sssss1596
Honestly, with the price difference between the Level 3 with 4 upgrade and the Level 4s I would really consider the Level 4s.
Sending you a PM now.
Old 02-03-2012, 10:40 PM
toad559's Avatar
0/11 sssss1508
one wy to find out, buyit and test it for urself, hardly anyone willever do the exact same setups in same car and have the same box. even if the subs will take those nice clean power to the coil, you will be moving them alot, u will put them to their mechanical limits. you will run into ton spiders, broken 3xjoints, rip surround, or anything is posible when running that much power. not sying it will happen but it can, too many variables. i myself would rather jus buy it and do my own testing. if your getting it anyways. gonna have to play and test it.
The Following User Says Thank You to toad559 For This Useful Post:
RustyWCA (02-04-2012)
Old 02-07-2012, 12:23 AM
0/11 sssss8594
Feedback Score: 55 reviews
this is EXACTLY what i was going to do, just with 12s instead...taking rise into account, u will be fine...the woofers will see mayb 1-1.2k each, depending on ur rise
Enclosures
Old 02-07-2012, 09:00 AM
0/11 sssss1181
I do think I am gonna say [email protected]#k and still buy level 4s instead and use the lanzar opti drive Amp
(4) dc audio level 3 10's with level 4 soft parts timsaudio 10" Subwoofers 8 08-15-2011 03:31 PM
[SOLD]3 DC Level 4 18s Dual 1 With Level 5 Coils fijunkie88 18" Subwoofers 25 02-04-2011 02:55 AM
whats the difference between a level five and a level four with a level five coil? mattintc10 (DC) 29 02-03-2011 12:12 PM
[Sold](2) DC Audio Level 3 12s with Level 4 D1 coils Like New! toaster 12" Subwoofers 12 03-30-2010 08:09 PM
[TRADED] DC level 4 15's w/level 5 coils and xtra spider Violence* 15" Subwoofers 16 01-16-2010 12:53 AM
