2.0K issues - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 02-05-2012, 11:01 AM
0/11 sssss1122
Feedback Score: 23 reviews
Default 2.0K issues
I bought a 2.0K brand new from codyj18 on last years presale. I received the amp around November of last year and it has been sitting in the closet since a week ago.
I am having a problem with the amp. Whenever I turn the volume loud (not max volume) the amp plays for about 5 sec then output completely cuts out. The power led stays lit and the protect led has never turned on. It seems to take about 15 minutes with the system off for the amp to start playing again. The amp's case is never hot.
The amp is powering a single ZCON 15D2. My voltage stays above 13.5V.
This is my third system in this car. I have never had an issue with any amp prior to this.
Pics of install:
Any thoughts??
Old 02-05-2012, 11:15 AM
MERQUE's Avatar
0/11 ssssss622
maybe its clipping or you're running it too low?
Old 02-05-2012, 11:21 AM
0/11 sssss1122
Almost impossible that I have a clipped signal. My hu volume is at 25, max is it 35. I have the gain set on the 2.0K no where near max.
I played the system for literally 5 sec (until the amp stopped working) a half hour ago and it still isn't working
I checked my RCA's many times and I even replaced them. This is the third system in this car. All I had to do was take the old amp out and put this on in. There shouldn't be any issues.
I am going to call in a warranty claim on Monday.
Old 02-05-2012, 11:27 AM
MERQUE's Avatar
0/11 ssssss622
that still does not mean you are not clipping. your HU could have very high output voltage RCAs and the little gain that you set the amp was way too high.
The Following User Says Thank You to MERQUE For This Useful Post:
codyj18 (02-05-2012)
Old 02-05-2012, 11:28 AM
newarkbeast973's Avatar
0/11 sssss7810
Do you have another amp you can swap back in? just to make sure nothing came lose or anything..
New build coming soon!!
The Following User Says Thank You to newarkbeast973 For This Useful Post:
edouble101 (02-05-2012)
Old 02-05-2012, 11:30 AM
0/11 sssss1122
Nope. Max 4v outputs at the HU. HU volume is no where near max volume. All other amps (JL Audio, Crescendo) I have ever used have had no issues.
0/11 sssss1122
Yes I do. I will do that.
Old 02-05-2012, 12:29 PM
0/11 sssss1122
Phuck. I wired up a JL Audio XD600/1 and it plays perfectly. I listened to 5 tracks at max listening volume (28 out of 35) and there are no issues.
Calling DC Audio on Monday.
Old 02-05-2012, 12:37 PM
RE_XXX's Avatar
0/11 sssss3182
I havent heard of an amp to quit just from sending a clipped signal.... if that was the case, every amp out there would atleast clip and quit once
Amps- Crossfire XS-8X
Wire- 6 runs Stinger
The Following User Says Thank You to RE_XXX For This Useful Post:
massivespl (02-05-2012)
Old 02-05-2012, 12:43 PM
massivespl's Avatar
0/11 sssss8409
seems like the amp just has a problem. DC should take care of you monday when u call.
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Loading issues 9515ROB General Car Audio Discussion & Questions 8 10-03-2011 05:44 PM
anyone else having issues? pitbull1078 (DC) 23 03-22-2011 04:17 PM
TL issues Highs On Bass General Car Audio Discussion & Questions 3 11-06-2010 02:00 PM
this could cause some issues Memphistahoe02 Off Topic Chat 22 03-25-2010 03:43 PM
About RD CS issues BigC-Expo Off Topic Chat 87 11-18-2009 01:07 AM
