.5 ohm stable? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 04-20-2012, 12:34 AM
BASSNUT
0/11 ssssss180
Default .5 ohm stable?
i'm ordering a DC 2kw and will be running 2 AQ HDC3-10s (D1) I have them wired together to present a total ohm load of 1 ohm BUT when i checked the final load with my ohmmeter it was actually .5-.6 ohms. will the 2k be stable at this load?
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-20-2012, 11:02 AM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Make sure that you actually got D1 subs. Some D1 coils will actually read .7. You should be fine.
Old 04-20-2012, 12:23 PM
BASSNUT
0/11 ssssss180
the coils do read about .7. . . Will it be fine for daily? Also what can I expect for power output?
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 04-20-2012, 12:34 PM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Should be fine for daily if your electrical is upgraded...shouldn't take much for a 2K at .5 though. The positive side is you'll never see the .5-.6 load on a reactive load. I bet you'll be closer to 1.5-2 ohm range for reactive.
Only way to see how much power you can expect is to clamp the amp and find out. Each setup is different and even the same equipment in a different box will yield results that are very different from the other...again due to box rise and your reactive load.
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
The Following User Says Thank You to jhg33k For This Useful Post:
aqspud15 (04-20-2012)
Old 04-20-2012, 01:05 PM
0/11 sssss1564
If you have to ask...
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Old 04-20-2012, 01:13 PM
BASSNUT
0/11 ssssss180
Ok thanks, everything in my car is upgraded (wiring, big 3, extra battery) except the alternator
I only ask because there is no rating for the amp at .5ohms and it doesn't say .5ohms stable
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
(2) Two Orion 2500d [2500x1 ohm] .5 ohm stable! Sonically_Sound Mono Amplifiers 20 11-17-2011 10:53 PM
1 ohm stable?? Alek17 General Car Audio Discussion & Questions 5 07-23-2011 02:34 PM
[TRADED]mmats modded dhc1400.1 2000 rms @ 1 ohm & 0.5 ohm stable kickerfanatic Mono Amplifiers 10 02-07-2011 09:27 AM
.5 ohm stable amp help! ''Bassman'' General Car Audio Discussion & Questions 7 11-23-2010 11:02 PM
.5 ohm stable constantprojects (Crescendo) 8 08-31-2010 03:27 PM
