amperage draw? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 05-10-2012, 11:29 PM
BASSNUT
0/11 ssssss180
Default amperage draw?
so in reguards to my post last week (just installed amp and not what it should be. . .) i got my gain all set and everything is correct now on my amp and the voltage draw after about 10seconds is down to 11V (not enough electrical i know i know. i'm working on getting a larger alternator. anyways I was in lab the other day and i figured i would do an amperage draw test on my amp and it is only pulling 80 amps. Granted this was only after 4-5 seconds. Does this seem low for this amp? (btw i'm running a DC 3.5k) I thought i'd be pulling over 110amps of current. i'm not really complaining because i only have a 95amp alt atm and with my current setup i'm doing just shy of 144db. i'm just curious if this seems low
team sedatephobia
2 AQ HDC3-10s
DC Audio 3.5kw
143.9DB
Old 05-10-2012, 11:36 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Im just gonna guess that the 80a draw that you got was incorrect. If the amps was only drawing 80a, then your drop most likely wouldnt be down into the 11s. I would venture to guess that you are drawing about 150a.
2 ohm amp VS 0,5 ohm amp - amperage draw? Dammed General Car Audio Discussion & Questions 0 04-19-2012 02:01 AM
what the amperage draw from a Memphis Mojo 16-MCD4KW LOUDHOE General Car Audio Discussion & Questions 10 12-14-2009 10:02 AM
Can you draw? 420guy Off Topic Chat 19 12-03-2009 12:24 AM
draw? Fosgate1 General Car Audio Discussion & Questions 7 08-01-2009 10:16 PM
Can anyone draw up a box please? bumpin buick Enclosure Discussion & Design Construction Help 7 01-31-2009 05:20 PM
