voltage drop to expect - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 05-11-2012, 12:59 PM
0/11 ssssss418
Default voltage drop to expect
Hey guys, im wondering wat voltage should i expect from my setup. Ill be running a dc 5k for substage and a sundown 200.4 for mids and highs. Ill be wiring the dc to .5ohms expecting a rise to about 1ohm or so. For electrical i have a 270amp mechman 2pos runs and 2 neg runs of xs power cca 1/0, 2 xs xp3000 and 1 xs d3400 in the front.
What voltage drop should i expect at full tilt
Old 05-11-2012, 01:06 PM
05TRAILBLAZER's Avatar
i ♥ Sundown Audio
0/11 sssss1946
i have same alt 1 kinetik 2000 a xs2500 n xs3000 my lowest voltage drop was 11.5v+ which i really bad some im getting me three more batts you need more power thats four sure just to be safe man
Old 05-11-2012, 01:15 PM
RustyWCA's Avatar
DC Ring Leader
0/11 sssss1292
Theres so many variables best way to know is wire it up and check =]
(855)SPL-DBZZ
(855)775-3299
GET CONNECTED
tacomaguy1's Avatar
0/11 sssss4401
starting at 14.75 dropping to 13.23, maybe down to 12.78 on big notes
Team Flex Issues
96 Blazer
4 18" Mayhems
2 TFE 8k's
Old 05-12-2012, 12:35 AM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
You have the potential to put out 7000w or more from those 2 amps. The 5k can draw up to 500a on its own and about 250 amps from the 200.4 Realistically, you will probably see about 500a of draw between the 2 amps. I would expect voltage drop into the low 12s with your current electrical. I would definitely recommend a second pair of XP3000s in the back.
When trying to figure out how much battery power I need to setup a system, I usually like to have twice the amount of battery power as I have total wattage. IN your case, you have potentially 7000w, so I would want 14000w of battery power. The XP3000s are rated for 3000w of power support, so 4 XP 3000s + the D3400 under the hood should give you substantial support to go along with the 270a alt. I always try to take the alternator out of the question when figuring how many batteries are needed since the amps are run off of the batteries and not the alternator. The purpose of the alternator is to keep the batteries charged and not to power your amps.
Here is another way to tell if you need more batteries. 12v battery resting voltage is about 12.9v, once your alt kicks in your voltage goes up to 14.4v. If you have voltage drop down below 12.9v, now you know that you have maxed out the amount of amperage that your alternators can supply and are getting into your batteries reserve power. Keep adding batteries until your full tilt voltage stays above 12.9v. The more battery power(reserve) that you have, the longer you will be able to play before you have to turn it down and let your alt recharge your batteries.
Hope this is helpful.
Old 05-12-2012, 08:34 AM
jhg33k's Avatar
n00b looking to learn...
0/11 sssss1531
Feedback Score: 31 reviews
Just a side note on the voltage drop....any amount of clipping will also cause more than normal drop. My last setup with a 5.0K I tuned with a DD-1 and thought I used a 0db tone but used the -5dB tone by accident (not paying attention). When I'd start playing boosted songs like Bigpimpin's or Decaf's mixes then I was dropping into the mid 11's with 3 group 31's, group 34, and 270a alt. Once I retuned I never saw below 12.8 at full tilt.
Long story short, any amount of clipping will also cause an added draw on your electrical.
|2011 Toyota Carolla S |2 Mmats HD4000.1's | Pair DC XL 12's w/AR cones | Average headrest score out of the trunk...will update after world finals
Voltage drop anyone? AMI CUSTOMS General Car Audio Discussion & Questions 14 03-11-2011 05:18 PM
voltage drop kirshland williams General Car Audio Discussion & Questions 9 10-03-2010 01:05 PM
Voltage DROP! mads10bass General Car Audio Discussion & Questions 70 06-30-2010 11:54 PM
Voltage drop?? king ranch General Car Audio Discussion & Questions 15 12-02-2009 07:01 PM
Voltage drop:( splvictim20 General Car Audio Discussion & Questions 60 12-10-2008 07:44 PM
