DC subs doing something weird - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 05-31-2012, 09:38 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Default DC subs doing something weird
Okay, I got 2 12" level 3 w/ level 4 softparts. Got them hooked up to a DB Drive Okur a7 2000.1 amp. I don't know if the settings on that amp is wrong or something...but I'm getting massive excursion...but no bass..wtf Someone help me please...do I have something set wrong on the amp? Had them hooked up to a hifonics HFI2000D and they were pounding it was wired at .5 ohms, still is wired at .5 ohms
my package is on here somehwere... someone find it lol
yeeeahhh.
Im banning you now...
Old 05-31-2012, 10:14 AM
RustyWCA's Avatar
DC Ring Leader
0/11 sssss1292
Did you change just the amp out ? Did any of the wiring to the subs change?
(855)SPL-DBZZ
(855)775-3299
GET CONNECTED
Old 05-31-2012, 10:15 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Yeah, I just changed the amp out. The wiring remains the same, Wiring @ .5 ohms on 10 gauge Knukonceptz.
I'm going to mess with the LPF...I just lost the whole...rattle my car thing...which is what I wanted
yeeeahhh.
Old 05-31-2012, 10:18 AM
audioarsonal's Avatar
Ja Marcus
0/11 sssss6975
I would venture to say they are out of phase.
Old 05-31-2012, 10:23 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Well the amp does have a phase knob on it..because they do seem to move only forward and back into their original place...and not back and forth.
yeeeahhh.
Old 05-31-2012, 10:29 AM
Ja Marcus
0/11 sssss6975
But that controls both drivers. If one is out of wired out of phase they will cancel each other out. Giving you very little sound but the subs still move. I would double check the drivers just to be sure. Make sure your jumpers are right on the coils and the leads going to the drivers are hooked up the same.
Old 05-31-2012, 10:32 AM
carshateme's Avatar
Basstastic!
0/11 sssss1808
The phase is 0 - 180...should it be on 90? It's at 0 right now.
I will double check the wiring tomorrow when I get home from work. Meanwhile I guess I'll be without bass for another day. I did a rush job on the jumpers. I may just rewire the whole thing (The terminals I use are screws (on the box) because my 10 gauge wire is nearly too big for my sub terminals) I may get some small ring terminals and wire them all to the screws...which mean I have to get longer screws
yeeeahhh.
Old 05-31-2012, 10:40 AM
0/11 sssss1564
I will double check the wiring tomorrow when I get home from work. Meanwhile I guess I'll be without bass for another day. I did a rush job on the jumpers. I may just rewire the whole thing (The terminals I use are screws (on the box) because my 10 gauge wire is nearly too big for my sub terminals) I may get some small terminals and wire them all to the screws...which mean I have to get longer screws
No.. leave it at 0... hes saying that the SUBS themselves are wired out of phase with each other. You probably crossed a pos/neg on one of the coil.
u scratchn ur ass or your head, but it could be both cause your heads in you ass.
Old 05-31-2012, 10:43 AM
Ja Marcus
0/11 sssss6975
Check the wiring and see if that's the problem. It sounds like it may be you just crossed a wire wrong somewhere. If it isn't the wires come back and I'm sure we can get it figured out.
carshateme's Avatar
Basstastic!
0/11 sssss1808
Meh, I'm almost certain I didn't...but at the time...when you're in a hurry, shit happens. guess I'll go to my local store and buy longer 5/16" screws. cuz the screws I have now...are too small for so many ring terminals...bad planning on my part. But lets say it isn't the wiring...then what else could it be?
yeeeahhh.
Weird???? BKNIGHTS Craigslist Deals 5 06-23-2012 12:05 AM
strapped amps making weird noises from subs treylittlefield (Sundown Audio) 10 02-17-2012 09:18 AM
3 subs weird ohm? Russellabt General Car Audio Discussion & Questions 17 10-28-2011 09:53 AM
So weird... Ryan1126 Off Topic Chat 28 04-07-2010 03:09 PM
People are weird Jh8909 Off Topic Chat 10 04-03-2010 06:01 PM
