Less than perfect airspace options - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 06-15-2012, 10:44 AM
0/11 sssss1181
Default Less than perfect airspace options
I have a 93 Chevy bubble caprice that I am trying to make hood loud. I've had mid 150's small cars before and I am trying to make this one as loud as possible on my budget. I want to know if 2 18' level 3 will get loud and sound good in 9.5 cubes net tune to 34hz? I know the website says 6 cubes but I wanted to get additional experiences
Old 06-15-2012, 11:26 AM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
You will be better off with a pair of 15s with the proper airspace. All you would be doing is choking off the subs and hurting your output. This is one of those cases where 18s arent the best choice. Smaller subs can get very loud too.
Old 06-15-2012, 11:33 AM
Mr.G6's Avatar
0/11 sssss4614
what does "hood loud" mean??
2000 Gmc Sonoma ext cab
Old 06-15-2012, 11:40 AM
jj53913's Avatar
0/11 ssssss720
I agree with Cody! I don't know the trunks of these cars other than they,are big, but think being a trunk install you could do a proper install with a pair of 15s and put higher #s up. I have only ran the xls and had good results with a little over 5cu ft per 18 but I ran lots of power to them too. I did an install in for a guy that was bound and determined to run my xls (when I sold them) and it was just under 10 and he ended up selling and going with 15s.
Sent from my PC36100 using Tapatalk 2
TEAM DC
Team SD
ebayID
ca.com References: Kenneth10483(BF), goodie (Traded), SPY (Sold to), kovemaster559 (BF), ExpoSport (BF) SPLluminator (traded&sold), Branham1127 (bf), NoPh33rRaCiNg (bf), Zookporter17 (bf)
Old 06-15-2012, 11:49 AM
0/11 sssss1181
According to the website the 15's can do 3 cubes optimum so I was gonna do 3 level threes if the 18's won't work. BTW when I say hood loud i mean street loud not meter loud. That is why I wanted to tune lower so I could maximize the lower notes carrying farther as opposed to tuning closer to a resonant frequency to meter higher
Old 06-15-2012, 01:04 PM
666WMD's Avatar
No idea what I'm doing
0/11 sssss1307
As was mentioned, you can throw more power at them so they'll work in that space. Or you can use poly fill so they "see" up to 40% more volume.
Polyfill Chart
Old 06-15-2012, 01:06 PM
reeftopia's Avatar
i always need more power!
0/11 ssssss517
Old 06-15-2012, 01:10 PM
0/11 sssss1181
^^^^^^ thats what I mean by hood loud
too much airspace for Level 3's? jfoodstamp (DC) 6 02-19-2012 10:58 AM
15" Sub that needs 1.25cuft of airspace C3 Customs General Car Audio Discussion & Questions 16 01-20-2012 02:45 AM
Is airspace just airspace no matter how you get it? bigdhenderson Enclosure Discussion & Design Construction Help 16 12-22-2011 08:19 PM
Airspace 45s take up? Bobby32 Enclosure Discussion & Design Construction Help 6 07-06-2010 04:41 PM
ported box airspace questions fosg8freak Enclosure Discussion & Design Construction Help 13 02-17-2010 05:06 PM
