LVL2 8 TS Parameters - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 06-30-2012, 09:33 PM
MisterGrubbs's Avatar
0/11 sssss2358
Default LVL2 8 TS Parameters
Did I miss them? M1's, I think.
Looking for D2 parameters
Thanks!
Old 06-30-2012, 09:39 PM
0/11 ssssss666
LV2 8" 10" 12" 15"
Mounting Depth 5.25" 5.5" 6" 7.5"
Mounting Hole Diameter 7.25" 9.25" 11" 14"
Motor Width 6.5" 6.5" 6.5" 6.5"
Weight 17.5lbs 18lbs 18.5lbs 19.5lbs
VC Diameter 2" 2.5" 2.5" 2.5"
Displacement .10³ ft .12³ ft .14³ ft .16³ ft
Magnet Weight 15lbs 15lbs 15lbs 15lbs
Power Handling
RMS/Peak 300/600 300/600 300/600 300/600
Impedance (Ohm) d2 or d4 d2 or d4 d2 or d4 d2 or d4
Sd 201.93 cm² 334.00 cm² 519.00cm² 872.00cm²
Vas 7.01 L 36.40 L 73.90 L 145.10 L
Cms 126.134 um/N 2.33e-04
m/N 1.96e-04 m/N 1.36e-04 m/N
Mms 157.47 g 93.47 g 131.94 g 168.60 g
Woofers | Amps | Accessories
//Home //Forum //Team DC //Records //Warranty //Contact/Dealers
Fs 35.71 Hz 34.1 Hz 31.3 Hz 33.2 Hz
Bl 15.29 20.89 20.89 20.89
Re 3.95 ohm 7.20 ohm 7.20 ohm 7.20 ohm
Qms 4.64 4.31 6.68 7.88
Qes .59 0.49 0.53 0.58
Xmax 16.5 mm 18 mm 18 mm 18 mm
Sensitivity 79.04 dB 86.5 dB 88.2 dB 91.5 dB
Suggested Sealed .5³ ft .5³ ft .75³ ft 2³ ft
Suggested Ported .8³ ft 1³ ft 1.25³ ft 3³ ft
The
Team DC Audio
Team Droppin Hz
Team Second Skin
Team Toolmaker
Team XS Power
Email -
0/11 ssssss666
the 8's are M2 t/s
10-15s are M1 lvl 2 t/s
Team DC Audio
Team Droppin Hz
Team Second Skin
Team Toolmaker
Team XS Power
Email -
Old 06-30-2012, 09:43 PM
0/11 sssss2358
So if I have older 8's ... TS parameters do me no good...
Lvl2 m2 8srecones different than original lvl2 8s???????? atomic_bronco2 (DC) 2 12-13-2011 04:27 PM
FS: brand new dc lvl2 8 D2 pedro123 8" Subwoofers 11 11-19-2011 10:07 AM
DC lvl2 12"? ludeman (DC) 0 10-10-2011 02:53 PM
(2) DC LVL2 8s surreal 8" Subwoofers 17 04-13-2011 05:00 PM
Sub parameters ianlahood13 General Car Audio Discussion & Questions 4 02-22-2011 11:01 PM
