DC Motor Strength vs. Cone Area + Decisions - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 09-01-2012, 10:42 AM
0/11 sssss1181
Default DC Motor Strength vs. Cone Area + Decisions
Ok as many of you guys know I am in the middle of a build with my caprice. I have 4k of power and around 6 cubes net and I am trying to determine what to do next. I am trying to see if their is a mathmatical way to do this part of system design. Correct me if I am wrong but Motor Strength is expressed in
BL
So I am hoping by giving three scenario's you will be able to help me understand better
Set up 1:
2 XL 15" Subwoofers with a BL of 22.73 with a RMS of 2200 each
Set Up 2:
4 Level 3 12" Subwoofers with a BL of 17.2 with a RMS of 900 each
Set up 3:
4 Level 2 12" Subwoofers with a BL of 24 with a RMS of 600 each
Which one would you do and why?
Old 09-01-2012, 10:59 AM
Matt3824's Avatar
0/11 sssss3754
Setup 4: 6 Level 2 10s
Most cone area and distributes power more. Will give more room to upgrade power in the future.
Old 09-01-2012, 11:02 AM
massivespl's Avatar
0/11 sssss8409
he asked which one and why. u sir failed at his question^
1 vital power 700.1 @ .33ohm
4 NSV3 18s
8 pwx crescendo 10s
4 juicebox 3100s
Old 09-01-2012, 11:06 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
I would do option 2.
More cone area than 1 and if you get them with level 4 coils the power handling shouldn't be too much different.
And BL by itself isn't important.
The number you are looking for is BL^2/RE. That is motor force. Not just BL.
Current Build:
#60sHereIcome
Old 09-06-2012, 07:14 PM
thorshammer's Avatar
Loyal Member
0/11 sssss2315
are we talking about in the trunk? If so it has been proven time and again that a pr of higher powered subs performs better than multiple subs.
Team DefJ
First Trunk in Iasca IDBL Bassboxing History to Average a 150+ after all 3 rds.
152.2 Legal Pr. of 10's out of a Trunk
153.1 Certified DbDrag Pr of 12's
Ported and Powered by Psychoacoustics
Old 09-06-2012, 10:44 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Dont listen to this guy about trunks he knows nothing!
Hi Rob!
Old 09-07-2012, 05:47 PM
0/11 sssss1181
Thanks for your help guys
Old 09-07-2012, 06:03 PM
0/11 sssss2649
Option 1 IMO.. If you only have 6 cu's, you don't want more cone area then 2 15's..
Old 09-07-2012, 06:12 PM
1ndatrunk's Avatar
Stinkin Linkin
0/11 sssss2172
Feedback Score: 30 reviews
If you have a "bubble" or "box" Caprice, then none of the above options would get you louder daily than a pair of XL 12s in a 4th order, ported through the rear deck. It would also keep you close to your target cuft goal, as well as power avaliable.
I've had a 94 Caprice, 88 Caprice, and currently have an 85 Fleetwood (same thing as the 88 Caprice), and all were louder with less subs in a 4th order vs any number of subs in the trunk. I can't comment as far as metering goes though, since thats not my thing
Audiopipe Nutthuggery at its finest
Old 09-07-2012, 06:24 PM
goatskindreams's Avatar
Do you even demo?
0/11 sssss1797
2 15s with 3 6" aeros?
Team AST-2 15" Everest Sound Labs Bdx.Powered by Flatline audio ba2
Team Psychoacoustics-11" Adjustable Psycho Port. 12 T3 Audio 6x9s for mids
single 18 vs. Cone area. btsteinb General Car Audio Discussion & Questions 54 03-23-2012 01:48 PM
Motor strength Fosgate1 General Car Audio Discussion & Questions 3 03-09-2011 05:02 PM
quick question about BL: motor strength. murderedtahoe General Car Audio Discussion & Questions 7 07-29-2010 10:55 PM
cone area nuboot General Car Audio Discussion & Questions 5 04-16-2010 04:23 PM
no sub for cone area noisycricket Car Audio Videos 10 03-17-2010 03:43 PM
