Answer needed ASAP - reconing - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 09-08-2012, 01:44 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Default Answer needed ASAP - reconing
Okay, I finally got started on reconing my sub. I got everything stripped, sanded, old lead tinsels are taken off. I notice my shims over lap a little bit...is this fine, or should I cut one a little shorter. Thank you for the fast response.
my package is on here somehwere... someone find it lol
yeeeahhh.
Im banning you now...
Old 09-08-2012, 02:05 PM
KTMrida4life's Avatar
0/11 sssss2271
Feedback Score: 33 reviews
Im no expert, and Ive only reconed 2 subs, but I made sure to not let that happen. I was worried it would throw something off...
PS, I used index cards long ways (vertically, standing up) and cut them to fit.
Old 09-08-2012, 02:09 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Yeah, I'm retarded. I put the shims in the wrong way, standing up...they're suppose to be sitting sideways.
Do the shims need to be very snug in the motor..because I have two shims and I don't know if I'm suppose to use both...
yeeeahhh.
Old 09-09-2012, 12:23 PM
thorshammer's Avatar
Loyal Member
0/11 sssss2315
Use both
Team DefJ
First Trunk in Iasca IDBL Bassboxing History to Average a 150+ after all 3 rds.
152.2 Legal Pr. of 10's out of a Trunk
153.1 Certified DbDrag Pr of 12's
Ported and Powered by Psychoacoustics
Old 09-09-2012, 12:29 PM
Austin175's Avatar
0/11 sssss4224
do you have a pic of it.
Ref's- Bass14(smd), ddbump(caco), GearGuy2001(caco),extremechevyman67(caco),pieper88(caco),
southparkgucci(caco),
(caco),
(caco),Mythyone(caco)
Zookporter17(caco), White91Formula(caco),dgaf(caco),Dman3047(caco),
Old 09-09-2012, 12:44 PM
Novicaine's Avatar
CACO Late Night Crew
0/11 sssss6135
I would try and get it snug or even tight because if there is any loosness in it you can have an off centered coil.
Old 09-09-2012, 12:53 PM
0/11 ssssss437
you want the shims tight and you want them in there in a uniform fashion.remember that the shims are keeping the coil centered in the gap.you will need to stack them just do it the same all the way around the coil
Old 09-09-2012, 01:16 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
Yup, that's what I did. My subs are already reconed. I am just waiting for 6 more hours to put em in a box.
yeeeahhh.
Old 09-09-2012, 01:35 PM
Mr.G6's Avatar
0/11 sssss4614
why? ive never waited 6hrs to put a sub in box and put power to it
never had a issue either.. i get done glueing and walk over to the ride and slap em in
ca glue with activator cures almost instantly
2000 Gmc Sonoma ext cab
Old 09-09-2012, 01:48 PM
carshateme's Avatar
Basstastic!
0/11 sssss1808
To give the goop time to dry. I've had my subs done since yesterday. I don't feel like putting em in too soon. Not to mention that I don't have any speaker wire laying around for them -.-'
yeeeahhh.
Question! Answer ASAP thanks! Mousemonster1232 General Car Audio Discussion & Questions 15 08-21-2011 03:10 PM
EQ/Crossover needed ASAP. rideit Wanting to Buy (WTB) 13 04-13-2011 01:44 PM
Need Answer Asap jt_buck General Car Audio Discussion & Questions 10 04-11-2011 07:35 PM
quick ? answer asap.. midnite toka General Car Audio Discussion & Questions 14 05-15-2010 01:08 PM
