DC Audio 10.0K - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 10-13-2012, 11:58 PM
0/11 sssssss32
Talking DC Audio 10.0K
Does anyone know if the new 10.0K is stable UNDER 1ohm if I wire up 6 subwoofers that are D4 it will give me a 1.3333 ohm load to start with before box rise if i wire them in series/ parallel.....so my question is a 10.0K stable if i wire 6 subwoofers that are D2 in series/parallel which is supposed to be 0.7 ohm before box rise.
i want to know how safe this is because if it is a GO I'm gonna strap 2 x 10.0K amps on 6 monster DC subwoofers and give it hell!!!
Old 10-14-2012, 12:14 AM
0/11 ssssss312
I can't say with 100% that you will be ok... But with the right Electrical you should be fine..your going to need one hell of an electrical system to back up to 10k.. And running them under 1ohm Will void your warranty.. Now with that being said I run my 7.5s strapped at .7 ( so each amps see's .35)
Old 10-14-2012, 12:16 AM
ridintwo6s's Avatar
0/11 sssss1791
Battery power and sufficient charging system is your key.
Old 10-14-2012, 12:22 AM
0/11 ssssss443
yes that's almost one of those "If you can do it properly you already know the answer" kind of questions.. Is this a pipe dream or do you have a major electrical setup already?
Old 10-14-2012, 12:24 AM
ridintwo6s's Avatar
0/11 sssss1791
One of those questions where if you have to ask its probably not for you.
Old 10-14-2012, 12:57 AM
0/11 sssssss32
Dual HO alts and 5 XS D3100's now to start with should get the 1 10.0k up and running fine I think. For the second 10.0k going in ill add another 5 xs batteries. Not a wet dream should be put together here within the next year if DC can keep stuff on the shelves. If anyone has seen Jeff Smith's ride 2 10.0K amps strapped at 1ohm.....is, to say the least, definately Lethal!!!!!
Old 10-14-2012, 01:55 AM
0/11 ssssss443
sounds like you already knew the answer to the question you were asking then hah. Sounds like a Br00tal build should be on the rise here. what vehicle?
Old 10-14-2012, 02:00 AM
0/11 sssssss66
mattp doesnt know hes barely breaking a 50....
The Following User Says Thank You to jesseadkins187 For This Useful Post:
gredysra (10-14-2012)
Old 10-14-2012, 07:40 AM
0/11 ssssss666
Thanks man. Battery power is key, you can never have to many. I have 17 in the xterra and will be adding 4 more once the large xs batts come out later in the year. For your set up I think 5 d3100s would be enough but id suggest 6 or 7 per amp.
Team DC Audio
Team Droppin Hz
Team Second Skin
Team Toolmaker
Team XS Power
Email -
Old 10-14-2012, 07:43 PM
0/11 sssssss32
Oh yeah I can't ever have enough batts for the 2 10.0's to sit on...How was world finals I seen some videos of your 4th order...those level 5 m2's love it. How did the carbon everything cones hold up to the power? Any word on the 10.0K shipment?
The Following User Says Thank You to drduke1984 For This Useful Post:
DC98hoe (10-15-2012)
Custom audio audio show & $500 bikini contest in lima, oh Josh Wahlie Competition Corner 2 08-07-2012 09:42 PM
Ampman audio Adire audio revolution d1500.1 car amp 1 0f 78 made thel.t.d.supply eBay 0 01-08-2012 03:30 PM
Polk Audio MM6501 vs. Image Dynamics CTX65 vs. Hybrid Audio I6 or others for ~$230 n023b General Car Audio Discussion & Questions 4 04-24-2011 09:41 AM
JL audio W7 10" in a JL Audio H.O box, JL audio 500/1v2 amp, stinger cap s10 with 4 15's Car Audio Packages 8 03-22-2009 12:50 AM
