Lots of Plexiglass to show off the Level 5s!! - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 12-20-2012, 10:39 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Default Lots of Plexiglass to show off the Level 5s!!
Just installed the full plexi port
CJs F150. Full Plexiglass Port and LEDs - YouTube
Old 12-20-2012, 10:49 PM
treylittlefield's Avatar
0/11 sssss5201
Feedback Score: 37 reviews
What's all the relays for?
2000 2dr Blazer
Old 12-20-2012, 10:51 PM
its_ray_ray's Avatar
OCD Member
0/11 sssss5696
Feedback Score: 23 reviews
Beautiful man
Old 12-20-2012, 10:52 PM
0/11 sssss1596
The relays allow me to turn the rear speakers off.
Old 12-20-2012, 11:11 PM
Homernuts's Avatar
0/11 ssssss396
Wow! I am soooo jealous.
Old 12-21-2012, 06:43 AM
0/11 sssss5201
And you need that many? Couldn't just put a toggle switch on that amp?
2000 2dr Blazer
Old 12-21-2012, 07:07 AM
0/11 sssss1596
Considering the way I have them hooked up, no. If I shut the amp off, then the fronts wouldnt play.
I have 3 4 channels in the truck.
1 200.4 on driver side- Channel 1&2 run the front door mids. Channels 3&4 run the rear driver side mids and are turned on with 1 switch controlled by the relay panel.
2nd 200.4 on passenger side- Channel 1&2 run the front door mids. Channels 3&4 run the rear passenger mids and are turned on with 1 switch controlled by the relay panel.
1 100.4 hidden under center console- Channel 1&2 run all front tweeters. Channels 3&4 run the rear tweeters and are turned on with 1 switch controlled by the relay panel.
Essentially all rear speakers are run through the relay panel so that I can completely shut them off. No need to have the side walls and rear doors playing while I am driving. Yes there are other ways to do it, but this is the way that I chose to do so. I wanted them completely shut off and not turned down. I also wanted each side of the truck on separate amps.
Old 12-21-2012, 07:11 AM
0/11 sssss5201
Gotcha. Makes sense. Never seen that done so was curious. I have the same issue, but just thought about running a loc-1 to turn that set of rcas down. How'd you wire up the relays?
2000 2dr Blazer
Old 12-21-2012, 07:14 AM
0/11 sssss1596
I did not build the relay panel. I stare at it and it just confuses me. Tony Candela, CE Auto Electric Supply, built it for me. It came with a very detailed wiring diagram that anyone could comprehend.
Old 12-21-2012, 07:15 AM
0/11 sssss1596
The relay panel also controls the amplifier master turn ons as well.
plexiglass sale rfmayhem Wanting to Buy (WTB) 5 06-06-2012 06:17 PM
Plexiglass Traxxstar504 General Car Audio Discussion & Questions 15 09-05-2010 08:21 PM
[SOLD] Lots and Lots of 2/0 cable super_duper Wiring, Electrical & Other Installation Equipment 70 06-09-2010 10:09 AM
Plexiglass question MeLykeLotion Enclosure Discussion & Design Construction Help 2 02-25-2010 05:56 AM
