dc level 5 m1 surround - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 12-30-2012, 03:44 PM
caloriu's Avatar
0/11 sssss2863
Feedback Score: 107 reviews
Default dc level 5 m1 surround
just trying to get some info on a level 5 m1 . i just bought 2 local one has the normal surround the other has what appears to be a white mesh inside. can anyone tell me if this was an upgarde ? also it seems that the outter foam is very brittal and easy to get damaged and fall off is this normal? have some pics for refrence . also the material is visable but there is no hole and the bottom layer is intact does this need a new surround or can it be used as is ? coils read fine and dont want to damage the sub more .
thanks cal
Old 12-30-2012, 06:32 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
On the one with the normal surround, look and see if it has AR stamped on the back.
What it looks like to me is you have 1 standard reinforced surround and one AR cone/surround.
The damage to the reinforced surround appears to just be cosmetic as well.
Old 12-30-2012, 07:16 PM
caloriu's Avatar
0/11 sssss2863
i just checked and dont see any marks on them . im sure you are right cody, you know ur dc lol. also im very picky and was wondering if its worth trying to replace the cosmetic one with a new surround?
thanks cal
Old 12-30-2012, 07:22 PM
0/11 sssss1596
The surround can be replaced, but you run more of a risk of damaging the cone and needing a full recone kit.
Old 12-30-2012, 07:31 PM
caloriu's Avatar
0/11 sssss2863
i understand and dont mind running it like this untill it gets worse then attempt to repalce the surround.
also i got a few spots where the screw hit the surround and its not threw so im thinking of using something to glue it what do u recomend? seems like this type of surround stops from making a hole but once u hit the inner core it graps and pulls the top layer. and if this surround rips during a hard jam would that cause damage to the coil or spider?
sorry about all the questions been looking around for these for awhile
Old 12-31-2012, 01:31 PM
thorshammer's Avatar
Loyal Member
0/11 sssss2315
You have one with the reinforced surround and one of the older foam surrounds. Both have the same throw and will function together just fine.
Now to fix your prob you need all purpose goop. Comes in a blue tube with goop in big red letters. You dont need to use alot. Just a bit on the hole area and the screw side. Its like rubber fiber glass lol Very strong and extremely durable and flexible. Nothing else works as well.
Team DefJ
First Trunk in Iasca IDBL Bassboxing History to Average a 150+ after all 3 rds.
152.2 Legal Pr. of 10's out of a Trunk
153.1 Certified DbDrag Pr of 12's
Ported and Powered by Psychoacoustics
Old 12-31-2012, 04:42 PM
caloriu's Avatar
0/11 sssss2863
i appreciate the info and u answered my next question before i even asked lol. i was going to ask if they work well together but you beat me to it .
i thank you guys for the help
Old 01-01-2013, 06:28 AM
caloriu's Avatar
0/11 sssss2863
thor,
is this the one ?
Old 01-04-2013, 03:24 PM
Loyal Member
0/11 sssss2315
Originally Posted by caloriu View Post
thor,
is this the one ?
Yes sir thats the one! I keep tubes in my toolbox, car, work etc... Its truly amazing stuff lol
Team DefJ
(2) 12" DC m1 level 4 with level 5 coils D2 drop in recone kits price easco1 (Fix My Speaker) 2 03-05-2012 05:52 PM
WTT 2 DC Audio Level 3 12'' with Level 4 coils for 10'' sub\s cman0655555 Car Audio Trader (WTT) 8 02-24-2012 07:57 PM
sa8 surround vs my boxer...surround loses :( green monster General Car Audio Discussion & Questions 33 01-24-2012 09:07 PM
whats the difference between a level five and a level four with a level five coil? mattintc10 (DC) 29 02-03-2011 11:12 AM
[TRADED] DC level 4 15's w/level 5 coils and xtra spider Violence* 15" Subwoofers 16 01-15-2010 11:53 PM
