Dc lvl 5 m1 18 - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 01-20-2013, 12:26 AM
0/11 sssssss69
Default Dc lvl 5 m1 18
Can you refresh my memory of the specs and ratings on the DC LVL 5 M1 18
Old 01-20-2013, 12:31 AM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
DC Audio - Specifications
My game is legit,
Old 01-20-2013, 01:09 AM
marquez7890's Avatar
0/11 ssssss628
A lot went into the design of this sub. We wanted an SPL sub without the drawbacks that some of the others encounter.
We had an idea, it was a sub with sick amounts of magnetic force but with a large gap
and cooling. This is something you don't see from other companies. But why would we be different? The answer is less coil failures and less re-cones. The only drawback (if it is one) you need a 73lbs motor to get the job done. Was it worth it? Yes it was!
The end result is a sub that has extreme amounts of output for the SPL lanes but reliable enough for a high-powered daily system.
When it was all done we ended up with a 73lbs triple stacked 1" slug, FEA optimized monster. We use a 8-layer flat wound 3" coil. Its available is D1ohm or D2ohm configurations. We also use upgraded multiple progressive spiders, upgraded cones, surround, lead wire, a cast basket and push terminals.
Key Features
• Extremely rigid non-pressed paper cone assembly
• Multilayered polymer foam surround
• Polypropylene dust cover with embossed DC logo
• 8”OD semi cup progressive roll spiders
• Extra heavy duty interweaved tinsel lead wire
• Cast aluminum black frame
• FEA analyzed and optimized motor assembly – Fully CNC machined
• Rubber mounting gasket
• Chrome spring loaded push terminals
• Dual 1ohm or 2 ohm 3” 8 Layer Hi-temp Aluminum voice coil wound on black anodized voice coil former
LV5
12"
15"
18"
Mounting Depth
8.25
9.5
10.5
Mounting Hole Diameter
11"
14"
16.75"
Motor Width
9.84"
9.84"
9.84"
Weight
78lbs
78.25lbs
80.5lbs
VC Diameter
3" Flat 8 layer
3" Flat 8 layer
3" Flat 8 layer
Displacement
.20³ ft
.24³ ft
.26³ ft
Magnet Weight
73lbs
73lbs
73lbs
Power Handling RMS/Peak
2000/4000
20,000 burst
2000/4000
20,000 burst
2000/4000
20,000 burst
Impedance (Ohm)
d.7, d1, d1.4, d2
d.7, d1, d1.4, d2
d.7, d1, d1.4, d2
Sd
494.00 cm²
791.00 cm²
1159.00 cm²
95 Honda Accord, Nook Hd+ tablet
Team Ascendant Audio 18",
2006 Civic, Zv4 10"
Old 01-20-2013, 02:24 AM
0/11 sssssss69
thanks guys.....
looking to buy dc audio lvl 5 motors or aka a blown lvl 5 loudaccent Wanting to Buy (WTB) 12 04-12-2013 06:23 PM
[SOLD] 2 12" DC lvl 4's with lvl 5 softpart's ( price updated, will split ) Austin175 12" Subwoofers 168 02-11-2011 05:09 PM
[SOLD] 2 15'' DC Lvl 4's/Lvl 5 Coils NoPh33rRaCiNg 15" Subwoofers 6 12-26-2010 10:31 PM
[SOLD] DC LVL 3 W/LVL 4 coil & extra spider oxsign 10" Subwoofers 19 09-09-2010 08:21 PM
[SOLD]18" DC lvl 4 w/lvl 5 coils- New Recone 99Bonney 18" Subwoofers 0 10-30-2009 05:48 PM
