XL M1 Enclosure size experiences. - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 01-24-2013, 09:49 AM
SPL Distribution Owner
0/11 sssss2983
Default XL M1 Enclosure size experiences.
I need to do some more work to lower the variables down at play here but apparently everything i thought would happen didnt so now i'm a noob again, lol.
I have 4 18" XL M1s in ~27cuft Net right now with no port length except for baffle which is 1.5".
I have ability to switch on\off 1,2,3 or 4 subs on at once.
When i had 1 or 2 subs going, i had 0 low end audible below 40hz.
When i have 4 subs going, low end barely is audible to about 36hz but thats it.
I threw in 7 35" long 2x4s in the port and BAM, low end came back just great down to the low 20s and clearily audible.
Now, i decided to test to see what the wall is peaking at right now before i seal the wall off and record a cabin gain sweep graph of the car before i start tuning..
Well, this is where it gets even more weird.
I have 2 ~6sqin holes in the port wall that need to be sealed up but thats the only 2 air leaks so far in the enclosure.
The car, at passenger side head rest ~28" from glass did 46hz sealed, 45hz outlaw.
Something weird going on here...
When only 2 subs are playing, it peaks at 57hz sealed, outlaw unknown.
So my first of many questions is-
Do these 18" XL M1s like extremely small enclosures?
I used to run Level4s and they liked large enclosures in my vehicle with street and wall enclosures but these XLs are confusing the hell out of me.
Old 01-24-2013, 11:43 AM
Matt3824's Avatar
0/11 sssss3754
In for this. I've got 4 XL m1 18s that I'm building a wall for in about a week.
Old 01-24-2013, 12:02 PM
team dc audio
0/11 sssss1268
how much power?
Old 01-24-2013, 12:39 PM
0/11 sssss2983
I have 4 5500ds wired to 2 ohm per sub
Old 01-24-2013, 02:20 PM
team dc audio
0/11 sssss1268
need level 5s...email rusty for price
The Following User Says Thank You to chris coggeshall For This Useful Post:
phatryan69 (01-25-2013)
Old 01-24-2013, 02:23 PM
Josh Wahlie's Avatar
< Pic from my build log!
0/11 sssss3196
5.5 cubes for the 18s
3.25 for the 15s.
Custom Box Builder (Ships all over the USA)
Shok Industries Dealer
Old 01-24-2013, 03:11 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
I would run 5.5-6ft3 net per sub to start with. The low end not being there was due to the fact that you had no port. You tuning was probably somewhere around 70hz or higher.
I would recommend 14in2 of port area per ft3 of net airspace and a tuning of around 33hz.
Old 01-24-2013, 03:45 PM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Ok, total cubic feet, in^2 of port, tuning?
Old 01-25-2013, 07:32 PM
0/11 sssss2983
I used to run 21,000w on 3 Level4s... I'm running each 5500d @2ohm right now per sub so they are seeing baby power for my types of installs.
3.25 for the 15s.
Thank you.
I have discovered why it wasn't there. My bare port is tuned to 36hz, this is why i was frustrated. One of my ext. processors has MAJOR faults internally which when bypassed raised my burp testing score up 7db. Now, the low end is back and better than ever! After i am able to finish gain matching and sealing the port completely, i will then start the tuning process.
27net right now, 320sqin of port as of right now tuned to 36hz. Issue solved as stated above.
I still needed recommended sizes for these subs so that was good to know.
My goal is to do 850dbs with stock windshield so wish me luck.
Old 01-25-2013, 07:51 PM
MopaRBumpiN's Avatar
0/11 sssss3819
Feedback Score: 35 reviews
For SPL purposes, my old XL 12s were best to be in 1.5 cubes before displace each.
Team DefJ, Team XS Power, Team Audio Technix
Headunit: Pioneer DEH-80PRS
Tweeters: Vifa XT25
Midbass: Silver Flute 8"
Highs Amps: Soundstream TN4.900
Sub: Cascade Design Omega 15"
Sub Amp: Incriminator Audio 20.1
Electrical: XS Power D2400, XS Power D3100
Deadener: Alpha Damp and Audio Technix 80 mil
Enclosure size for sa8v2 with pr laextreme5 (Sundown Audio) 1 06-28-2012 02:17 PM
Recommended enclosure size for XFL? Ryan1126 Enclosure Discussion & Design Construction Help 3 11-16-2011 06:05 PM
Enclosure size for Btl N2 12? Colbyjack General Car Audio Discussion & Questions 3 10-31-2011 12:56 AM
Need Help on enclosure Size. BANGINKOTA Build Logs 1 02-10-2011 03:22 PM
I have a t3 tsns 15 what size enclosure More spl General Car Audio Discussion & Questions 12 05-22-2010 10:10 PM
