rattling sound and noise from my level 5 12 inch - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 03-15-2013, 06:22 PM
0/11 ssssssss9
Default rattling sound and noise from my level 5 12 inch
i noticed today that my sub making a rattling sound and hit noise when i crack the volume up.
i didn't touched the gain for a while and the noises come when i am on high volume.
it wast like this before i must say.
so i took the sub from the box to see i i can hear from where this noise is coming.
didn't hear nothing special i noticed that one of the leads is kinda touching the cone and there is
leads marks on the cone.
when i play the sub all volume up on free air i don't hear hitting sound only low rattling sound
when i put it back i can hear something hitting or hitting sound and rattling on a bit low volume.
Ive also checked the cooling hole on the bottom if there is a FOD in it didn't find nothing and the sub looks aligned.
what can it be ?
is it possible the spider lost there stiffness and i am hitting now the XMAS ?
Or is it the box fault ? too much port area ? or the port area is too little ?
Old 03-15-2013, 07:13 PM
team dc audio
0/11 sssss1268
have you pushed up on the cone to look for a small tear where the cone meets the spider?add ca glue there and let er rip.
Old 03-15-2013, 07:20 PM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
i had a loose speaker wire connection do something similar to what your talking about,
once i figured it out and did it right, no more noise, there was a few burn marks on the wire where i guess it was getting hot and arcing out at full tilt
Old 03-15-2013, 07:21 PM
sthrnbumpn's Avatar
0/11 sssss2961
just something to check
Old 03-15-2013, 07:55 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
a friend though he blew his sub when it unloaded badly. we took it out of the box and it turned out the spider came unglued from the basket so i held the spiders in place and checked for coil rub. when it was aligned i ca glued the shit out of it and it is back pounding hard as ever.
My game is legit,
Old 03-15-2013, 08:07 PM
richdog102's Avatar
Handing out Pimp slaps!!!
0/11 ssssss925
If you have a loose lead and you see marks on the cone you just answered your question. When the sub is in the box the turbulent air inside the box will cause the lead to hit the cone harder buy single sided foam backed tape from home depot and put it on the cone between the lead and the cone it will stop the rattle. I had the same problem. And that worked for me.
Old 03-15-2013, 08:22 PM
scfaust's Avatar
0/11 ssssss848
man i tell u i had the same issue and it would pop real loud and they gave me the run around hope u get the sh!t right ive been seeing alot of the same type of post about dc lately
AlphaDamp CLD Tiles - Get more sound deadening using less sound deadener
Old 03-15-2013, 08:29 PM
0/11 sssss1235
m1 level 5s in general rip leads on triple joints often. If your having tinsel slap there is most likely something wrong
95 Chevy Full Size Van
12 DC Xl M2 12's 6:1 4th order
3 DC 10ks
9 XS D7500s
Singer 350a & 2 275a Alts
Old 03-16-2013, 04:51 AM
0/11 ssssssss9
when the sub on the box the sound is really bad noise and it sound something hitting the cone really hard.
could it be that the sub maxing out ?
Old 03-16-2013, 05:00 AM
graham's Avatar
Tinder Douchebag
0/11 sssss7122
Lol my sub was doing the same thing and turns out i just forgot the tighten the bolts completely (tnuts and bolts)
Otherwise try inverting the sub to see/hear exactly where the noise is coming from.
team graham
SD-2 makin a rattling noise? Ryan1126 (Sundown Audio) 5 12-06-2011 12:49 PM
4 10 inch level 4s scfaust Enclosure Discussion & Design Construction Help 2 03-23-2011 07:08 PM
wtt 18 inch dc level 4 ralstoneric88 Car Audio Trader (WTT) 3 08-13-2010 04:19 PM
D1 15 inch dc audio level 4 with level 5 coil rachidfunaki 15" Subwoofers 43 06-22-2010 01:56 AM
15 inch dc level 5 or level 5 spl Craig28 Wanting to Buy (WTB) 3 06-17-2010 03:52 PM
