goal of 150 help me - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 03-26-2014, 11:08 AM
0/11 ssssss155
Default goal of 150 help me
First I must say very impressed with my subs I recently purchased 2 18" dual 1ohm lvl3 with lvl4 coils. My setup consists of the subs a box I built 12.65 cubes after displacements tuned at 30. My amp is a massive d8000 so it's [email protected] ohms. My truck is a 2000 escalade. I went to my first comp with all stock electrical no extra batts and a sundown saz1500 and did a 145.7 do u think I can break 150 with the extra power. I now have a 240 amp alt big 3 and 2 batts. It is significantly louder. Will the subs handle the power. I'm a first time dc user and noob competitor. Any help is http://i39.photobucket.com/albums/e1...ps2jdp4bwn.jpg
Old 03-26-2014, 11:39 AM
RustyWCA's Avatar
DC Ring Leader
0/11 sssss1292
I think the best advise anyone can give you is box development, Keep the power and subs you have, start testing with them ( you will need a termlab) once you know the peak of your ride, then start playing with the port length, changing it 1 inch at a time till it peaks out. that would be the first thing I did to see what your set up will truly do once tuned, then you can add some power to it.
(855)SPL-DBZZ
(855)775-3299
GET CONNECTED
The Following 2 Users Say Thank You to RustyWCA For This Useful Post:
Crunk (03-26-2014), Fatmeskin (03-26-2014)
0/11 sssss1015
youll need some meter time , seat placement can be worth a fair bit , also the placement of the box , batterys etc can all add up on the meter , also check the box for leaks around the subs
The Following User Says Thank You to TeamSDLuke For This Useful Post:
Old 03-26-2014, 11:57 AM
0/11 ssssss892
you should be able to hit 150 with that set up, you need a meter and tuning and help from someone that has exprence in spl
The Following User Says Thank You to Crunk For This Useful Post:
Old 03-26-2014, 12:47 PM
BallzFast's Avatar
Peel & Seal works!
0/11 sssss7087
Feedback Score: 41 reviews
are you going to be using the system daily or make it a comp system to hit numbers?
if daily i would say to make a designated burp box for comps only and install it the day before the comp.
My game is legit,
Old 03-26-2014, 01:50 PM
team dc audio
0/11 sssss1268
The boss speaks the truth... His advise has helped me a shit ton the last couple years
Old 03-26-2014, 02:11 PM
team dc audio
0/11 sssss1268
Old 03-26-2014, 03:18 PM
0/11 ssssss155
I'll be adding batteries tonite and maybe drive to Austin Friday after work to use my buddies termlab and see where I'm at. The system is a daily setup it's in my wife's escalade since my f250 doesn't have the room lol. I'm probably gonna see if I can have someone design a box for me once I get my power right. Thanx guys there is a comp on April 6th I curious on what it'll do. It's already a lot louder than it was at the last one. But my electrical couldn't keep up with my amp.( it would go into protect) hopefully this will stop that from happening.
Old 03-27-2014, 11:08 PM
0/11 sssss1015
is there any dampening done to this vehicle , I think subs up , port to the rear would get you good results
Old 03-27-2014, 11:24 PM
rocketboy1000rr's Avatar
Team DC Audio
0/11 sssss2782
.....and OTHERS..... .
2014/2015 - Kaos 4 - Top Dog - Loud n Low - Mayhem - MWSPL Champion
6 DC 9 K's on 6 SMD 18's
162.9 Db @ 44 Hz.
*FIRST 160+ DB for 1 1/2 minutes straight... IN HISTORY!!
ISPLL 2015 WORLD Champion - All Around W4 - Real SPL H - Subsonic Suicide Unlimited
painful lows is the goal nuboot Team Teamless 12 02-17-2012 07:59 AM
Goal: 50's from the trunk. markt3307 General Car Audio Discussion & Questions 19 03-02-2011 12:00 PM
My goal, let's see if I can do it! lunari General Car Audio Discussion & Questions 6 01-21-2009 09:42 PM
Impala ... goal: 16kw + 4 18's sholiz Build Logs 2 09-25-2008 07:07 AM
