Best DC amp for Four M1 18"XL's - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 04-14-2014, 05:08 PM
NESPL's Avatar
CACO Promoter
0/11 ssssss298
Default Best DC amp for Four M1 18"XL's
I'm planning to buy a new DC Audio amp for this season, but unsure if I want the 7.5k, 9.0k or the 10k. It'll be powering 4 18" XL M1's, all are dual 1 Ohm coils. I could wire to .5 ohms or 2 Ohms but of course .5 would be better. Since I already have the subs, along with a few extra recones I really don't want to have to buy a different coil configuration. Anyone know if these will be ok if I did wire them to .5 ohms?
It'll be used for SPL comps and well as demo's.
As for electrical, I have an Ohio Gen 320 amp Alt just for the bank, and 6 Reikken jb2409 batteries, so far.
2005 Astro, (4) DC 18" XL's, Hifonics Sampson ~ 157.7 So far
Old 04-14-2014, 05:19 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
a little more alt power would be best, more battery too... they'll run .5 without issue if kept electrically happy
Old 04-14-2014, 05:58 PM
ridintwo6s's Avatar
0/11 sssss1791
Get the 9.0.
Had mine strapped at .46 and .5 and no problems ... never got warm with less theb that for electrical.
2013: 4 12s no wall mid 50s
Team HateD
Team Sundown
129.9 SBN 2013 Champ
Old 04-14-2014, 07:08 PM
0/11 ssssss666
Since your running 12v batts I'd suggest the 10.0. It makes over 2500watts more power then the 9.0 on a 12v system.
Team DC Audio
Team Droppin Hz
Team Second Skin
Team Toolmaker
Team XS Power
Email -
Old 04-14-2014, 08:36 PM
NESPL's Avatar
CACO Promoter
0/11 ssssss298
I have no plans to bump up to 16-18v so the 10k would be a good option. Just curious if anyone has run these at .5 and not had any meltdowns. As for voltage, might bump it to around 15.0-15.3 for burps, but not concerned about that just bumping it.
Old 04-14-2014, 08:56 PM
ridintwo6s's Avatar
0/11 sssss1791
I have no plans to bump up to 16-18v so the 10k would be a good option.Just curious if anyone has run these at .5 and not had any meltdowns. As for voltage, might bump it to around 15.0-15.3 for burps, but not concerned about that just bumping it.
I said 9k because of this reason.
Ive seen a failure with one about 2 minths in @ .5 with 6 batterys and a uograded alt. Beside its not much of wattage increase to the 10k
Team HateD
Team Sundown
Old 04-14-2014, 09:09 PM
0/11 ssssss666
Personally I have ran my pair of 10.0s at .5ea for over 2 years, with no issues. Also I only know or 3 10.0s being in for repair, 2 or which was damaged in shippping and 1 was noted by ARC as being from customer abuse. Regardless the amps, running below 1ohm you take a chance, and the 10.0 has proven to be more efficient.
Team DC Audio
Team Droppin Hz
Team Second Skin
Team Toolmaker
Team XS Power
Email -
Old 04-14-2014, 09:24 PM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
Lets take a moment and reflect on some amp dyno tests.
The Following User Says Thank You to codyj18 For This Useful Post:
coroa_jeff (04-15-2014)
Old 04-14-2014, 09:25 PM
0/11 sssss1596
The 10k shits all over the 9k on a 12v system.
Old 04-15-2014, 12:28 PM
RustyWCA's Avatar
DC Ring Leader
0/11 sssss1292
Anas 10.0s are the first ones ever made, still going strong =]
(855)SPL-DBZZ
(855)775-3299
GET CONNECTED
The Following 3 Users Say Thank You to RustyWCA For This Useful Post:
coroa_jeff (04-15-2014), NESPL (04-16-2014), walwalka (04-15-2014)
how does this look for 3-10" xl's? newarkbeast973 Enclosure Discussion & Design Construction Help 18 07-25-2012 04:55 PM
2-12" xl's newarkbeast973 (Fix My Speaker) 1 02-29-2012 09:47 PM
2-12" d1 xl's newarkbeast973 12" Subwoofers 30 02-29-2012 09:36 AM
New Amp! 2 12" XL's on 4k+ slapuhho Car Audio Videos 17 04-12-2011 04:30 PM
