Single dc xl m2 15 - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 11-09-2014, 07:29 AM
0/11 sssssss26
Default Single dc xl m2 15
Dc suggests 3 cubes. I was going to do 3-3.5 net with a single 6" areo. One guy said he would do no less than 4cubes and suggested 5cubes with a 8" areo... Thoughts on this? Sub will be slightly underpowered for now ~2k
Old 11-09-2014, 08:04 AM
sthrnbumpn's Avatar
0/11 sssss2961
Feedback Score: 21 reviews
i could be wrong, but i got 28" of port area for a 6" aero.
right now i gotta xl 15 in a box with 59" of port an a 2k amp,
its loud but when it gets out of tuning range its less then desired. could be design tho
Old 11-09-2014, 08:35 AM
0/11 ssss31258
6" aero will work. more would be better since 6" is right at the vent mach where you actually need the flares of the aero.
as long as you keep the tuning around 33hz, the 6" aero will be fine
3 cu ft vs 5 cu ft won't make much difference (and if you never build both you'll never know)
but, if you have the space for 5 cu ft, you could go 4th order bandpass 2cuft rear & 2.5 cuft @55/hz (6" port 5.5" long)
and be louder/ sound better
Old 11-09-2014, 08:45 AM
0/11 sssssss26
Hmm... Thanks thought about a 4th but fitting that is going to be hard. 30x30x15 is really the max I can go without modification. 96 integra hatchback I'd like to keep the privacy cover so that's why 15 high is max
Old 11-09-2014, 08:48 AM
0/11 sssssss26
Top and bottom might work I could face the sub down and build into the spare tire compartment too for the sealed section
Old 11-09-2014, 09:03 AM
0/11 ssss31258
yeah, in that car I'd go 3.5cuft @33hz.. sub and port fired back
try for 16.5 high the cover probably clears it
Old 11-09-2014, 09:23 AM
0/11 sssssss26
I don't think it's going to ice measured a few times and have built a couple boxes for this car already. Always for 12s so i could face them back.
Can I change this 4.0 f^3 single 15" enclosure into a single 1.5-2.5 12" enclosure? graham Enclosure Discussion & Design Construction Help 7 02-18-2014 09:19 AM
t-line for a single 12" and single sheet of mdf? (VVME RD-12) graham Enclosure Discussion & Design Construction Help 0 06-13-2013 05:01 AM
Single SMD 18" & Single Mayhem 18" __d_a_v_i_d__ Car Audio Videos 0 04-11-2012 05:42 PM
A single 2000rms 12 or single 1500rms 15 which is a better set up 1993burban General Car Audio Discussion & Questions 12 01-23-2012 06:32 PM
single 10 nuboot Enclosure Discussion & Design Construction Help 22 12-16-2009 09:22 PM
