DC 5k under 1ohm - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 01-01-2015, 01:13 AM
0/11 sssssss77
Default DC 5k under 1ohm
I was curious what the lowest people run these daily at.
Even if I wire my subs to 0.25 I should be half ohm after box rise and such. Would this be too low? What about 0.33 or 0.5 (before box rise)
Old 01-01-2015, 01:36 AM
SINTORMAN's Avatar
157.28db,41hz +Increasing
0/11 sssss4907
Feedback Score: 17 reviews
yes half ohm reactive probably will protect instantly. and considering that is double the rated current flowing through the output fets your amp won't live long. Maybe a burp but .25 daily is just stupid IMO. .35 is still dangerous but more acceptable. .5 daily is fine.
Current Build:
#60sHereIcome
Old 01-01-2015, 02:05 AM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
you cant rely on box rise in music/daily
tez4life (01-01-2015)
Old 01-01-2015, 02:07 AM
0/11 sssssss77
Maybe I'm using the wrong terminology but like for instance right now I'm at 1.33 but if I hook a dmm up to the end of my speaker wire leads I get 1.7
Old 01-01-2015, 02:09 AM
Authorized Vendor
0/11 ssss14115
that's not caused by box rise. rise is while the subs are moving/playing. the resistance your reading is due to speaker wire/connections /etc
Todd Dupler's Avatar
Team SPL Farms
0/11 sssss5000
Id be ok with .5 ohm dc nom w decent ele. Below that is asking for trouble imo
01 Volkswagen Golf 2 door
Kenwood ddx470
Old 01-01-2015, 02:11 AM
0/11 sssssss77
So like if I wire to 0.33 as long as the final resistance at the end of the leads is 0.5 or higher I should be fine or do I need to stay above 0.5 so the final is around 1ohm
Old 01-01-2015, 02:13 AM
Authorized Vendor
0/11 ssss14115
your multi meters reading is what your amp sees. keep in mind some multi meters have resistance in there leads/the unit which can make it read a little higher then actuals
Old 01-01-2015, 02:15 AM
Team SPL Farms
0/11 sssss5000
Safer at that .5 for sure. Much more forgiving
Kenwood ddx470
0/11 sssssss77
Yea I realise it will be what the amp sees but what I'm stumped on is when like you said 0.5 is fine do you mean like factoring in wire resistance and all like even if I wire subs to 0.3 but final resistance is 0.5 or higher I'm good.
6-7k at 1ohm or 4-5k at .5? dr3wzrdroid1 General Car Audio Discussion & Questions 13 03-12-2014 12:03 PM
W T T for a 3k @ 1ohm amp oxsign Car Audio Trader (WTT) 17 01-25-2011 06:13 PM
3k at 1ohm slammed636 Wanting to Buy (WTB) 24 03-28-2010 09:04 PM
Wtb 4-5k @ 1ohm Cadillac Wanting to Buy (WTB) 3 03-27-2010 11:05 PM
1100rms @ 1ohm/12.5V SLOWnSTEADY Mono Amplifiers 3 08-06-2009 07:45 PM
