Why Level 4 vs. Level 2? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 02-03-2016, 03:21 PM
0/11 sssssss33
Default Why Level 4 vs. Level 2?
I'm looking at the specs of the Level 2 sub and it looks to be a really solid performer for the price with high BL and good xmax. Other than power handling would there be any reason to upgrade to the Level 4? The 4 has a bit more xmax but a lower BL-seems to me the LVL 2 is a better buy?
Old 02-03-2016, 03:42 PM
0/11 ssssss543
Bl is lower probably due to the sub being a dual 1 or dual 2.vs the lvl2 being a dual 4 to get an accurate comparison you need to do bl^2/re most subs are measured in series so the dual 4 will be around 7.6 and the dual 2 around 3.8 if dual 1 it's probably 1.9
Old 02-03-2016, 03:45 PM
0/11 sssssss33
I'd be comparing the D2's. Main reason I'm asking is a dude here locally has a nice price on a Level 4 and if it's worth it I'll go that way.
Old 02-03-2016, 04:07 PM
Jeffhulbert50's Avatar
Authorized Vendor
0/11 ssss14115
bl is for refrence, shouldn't be a decision maker
Old 02-03-2016, 04:17 PM
0/11 ssssss543
Bl^2/re on the lvl 4 is a bit higher but not much. Depending on your power available box used and goals it's really tough to say which would be better for you
Old 02-03-2016, 04:50 PM
0/11 sssssss33
As it was explained to me a higher BL has more strength and work "harder" over a given distance. Like if two speakers had the same Fs and xmax the one with the higher BL would be louder? Am I mistaken?
Old 02-03-2016, 05:11 PM
Authorized Vendor
0/11 ssss14115
the one with the higher bl would be (in theory) louder per watt but theres a ton in the mix still. take your example. they can have the same fs, same xmax and higher bl on one BUT the suspension could be a ton stiffer and moving assembly a lot heavier. BL is a static measurement so only valid at a stand still just like FS doesn't dictate freq possibilities.
Old 02-03-2016, 05:22 PM
0/11 ssssss543
If you are just doing a straight switch on same power I don't think it would be worth it if you invest in a custom box and future power upgrade then go for it.
(2) 12" DC m1 level 4 with level 5 coils D2 drop in recone kits price easco1 (Fix My Speaker) 2 03-05-2012 05:52 PM
[SOLD]3 DC Level 4 18s Dual 1 With Level 5 Coils fijunkie88 18" Subwoofers 25 02-04-2011 01:55 AM
whats the difference between a level five and a level four with a level five coil? mattintc10 (DC) 29 02-03-2011 11:12 AM
[TRADED] DC level 4 15's w/level 5 coils and xtra spider Violence* 15" Subwoofers 16 01-15-2010 11:53 PM
