powering a lvl 4 xl ? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 03-10-2010, 08:43 PM
0/11 sssssss30
Exclamation powering a lvl 4 xl ?
Need to power a lvl 4 xl and it's still new and stiff as hell. I need to power it without harming the sub . I don't have an amp yet I am considering saz 1500. Can I just run it 2 ohm and use 800 watts until it breaks in or can it take the 1500 plus at 1 ohm if the gains are turned down ? I hear they can take more daily, is this even enough ? Thanks
Old 03-10-2010, 08:44 PM
Pieper's Avatar
Winston Churchill > You
0/11 sssss9716
Feedback Score: 84 reviews
First of all, you don't have a choice between the two. What is the ohm load on the sub. If its dual 1 you can only run it at .5 or 2 ohms.
Old 03-10-2010, 08:53 PM
GiGLZ's Avatar
0/11 ssssss514
on the subject.. is it bad to underpower a sub?..
Old 03-10-2010, 09:33 PM
The A Team's Avatar
Active Member
0/11 ssssss817
No its not bad to under power a sub, but it is real bad if you dont know what you are doing!!! Its called user error.
As for power on a XL i would be looking at atleast a 2000+ watt amp for that sub. In real world you wont get anywhere near 1500 watts from that amp daily at rated impedance. I tested one of those amps once and was very disappointed with the results.
I play lower, louder, and longer thanks to
Stetsom amplifiers
Powering soundstream xxx6500 Dhern409 General Car Audio Discussion & Questions 12 12-13-2009 07:31 AM
Help for powering system inside. Bologna General Car Audio Discussion & Questions 8 10-11-2009 03:43 PM
