Gain Setting - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 04-11-2010, 10:22 AM
0/11 ssssss208
Default Gain Setting
Ok, I just installed my Q15's on my DC PAI-2000.1.
I am trying to tweak the system, but it seems like the subs can handle more power. I have the gain set @ 80%+/-. Should I leave it there and focus on my EQ setting on the HU or is it ok to turn gain up 100%?
BTW its loud...I may need a new HU, because this one keeps skipping when I turn the volume up...
Old 04-11-2010, 10:33 AM
ascitiesburn69's Avatar
0/11 sssss1645
What impedence are your Q's? and is that box sealed?
Team S.P.E.A.D.
Trunks FTW
Old 04-11-2010, 11:49 AM
0/11 ssssss208
Yeah, box is sealed and the subs are dual 1's. I have each sub wired to 2 ohm the ran them both parallel from the amp.
Don't get me wrong, it's nasty and clean. I pumped them pretty hard for about 10 minutes and neither the subs nor the amp even started getting hot. Good times.
Old 04-11-2010, 11:57 AM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Feedback Score: 25 reviews
80%? 100%? NO. Do not turn the gain up all the way. There's a tutorial here on how to set gains or else your subs will be clipped like hell.
- CALI SOUNDS
- VERTEX AUDIO
Old 04-11-2010, 12:12 PM
0/11 ssssss208
That's why I am asking. The subs don't seem to be clipping.
I am just going to set at 80% for now and adjust my EQ settings.
Old 04-11-2010, 02:40 PM
0/11 ssssss208
I posted a link to the setup here:
15's in ek - Car Audio Classifieds
Old 04-11-2010, 02:56 PM
gbo559's Avatar
Veteran Member
0/11 sssss4814
Are you using like 8 gauge for power?
Don't seem to be clipping? People usually can't tell when a sub clips by just listening to it.
- CALI SOUNDS
- VERTEX AUDIO
Old 04-11-2010, 02:59 PM
FOGEL A.KA.MCLOVIN's Avatar
0/11 ssssss307
never put ur gain 100% if u do 1. it will sound like sh*t 2. ur amp will clip like hell 3. the clipping will blow ur subs.
Old 04-11-2010, 03:01 PM
0/11 ssssss307
o btw u could probly get louder with 1 of them Q's in a ported box instead of sealed
Old 04-11-2010, 03:04 PM
Bologna's Avatar
Ad ministrator
0/11 sssss2872
8ga power wire? get some 1/0 and call it good
Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
Gain setting for soundigital line muriloalvares General Car Audio Discussion & Questions 7 03-03-2011 07:04 PM
Amp Gain Setting the Right Way whitedragon551 General Car Audio Discussion & Questions 19 03-30-2010 01:20 PM
setting Gain help tylork92 General Car Audio Discussion & Questions 4 11-25-2009 10:16 PM
Setting AQ2200 Gain with DMM ?'s got boost General Car Audio Discussion & Questions 8 11-19-2009 09:22 PM
Quick help needed-gain setting on strapped amps toolmaker (Sundown Audio) 5 08-23-2009 06:31 PM
