Question on DC setup - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 05-16-2011, 10:34 PM
0/11 ssssss149
Default Question on DC setup
Plan on doing 8 10's in a sealed v in my trunk over the summer. Going to run either a Crescendo bc5500 or a DC 5.0k @ .5 nominal in hopes of seeing 1 for daily after rise. Wondering if I should run the level 2's or level 3's. I know the 3's better suit rms needs, both woofers could handle 600 daily though right? Also would there be that much of an audible difference if any?
Old 05-17-2011, 02:14 AM
Droppin' HZ Car Audio
0/11 sssss1596
Feedback Score: 26 reviews
You will be fine with either the level 2 or 3 subs with running 8 on a 5k. As long as you don't plan on adding any more power then i would go with the level 2s to save some money on subs and shipping costs.
If you have any questions or need pricing just shoot me a pm and I'll be glad to help.
Old 05-17-2011, 02:16 AM
jt_buck's Avatar
don't shoot
0/11 sssss4423
Why run sealed?
Old 05-17-2011, 11:30 AM
0/11 ssssss149
Alright, sweet and thanks man I've already been contacted by my local rep here in FL if I need any other help though I'll let you know.
And it would be a pseudo bandpass I guess, sealed v firing into the cab through the rear seat opening sealed off from the trunk. Plus I don't have much room to play with. Unless I fiberglass or piece together and build in the trunk the most I can get is about 9 cu ft net before displacement. I realize this is probably enough space for ported but not enough physical space to mount all subs and have a port. You think I should run ported though?
Old 05-17-2011, 12:15 PM
0/11 sssss1596
If you want to fit 8 in your truck then I would stick with the sealed enclosure. For 8 level 2 or 3s 10s sealed you are gonna be looking at about 9ft3 total including sub displacement. If you try to add a port then you are going to sacrifice airspace to do so or you would have to drop down to 6 subs.
SBN! setup question bad4health General Car Audio Discussion & Questions 2 03-07-2011 05:31 AM
Setup Question Fly ty 215 General Car Audio Discussion & Questions 2 02-21-2011 05:29 PM
***every 1 look*** dc audio setup question/help nybass General Car Audio Discussion & Questions 11 02-16-2011 02:11 AM
Another new setup question Scapelli21 General Car Audio Discussion & Questions 15 10-05-2009 03:52 PM
Question about 18v setup canyouhearmatt General Car Audio Discussion & Questions 8 01-03-2009 01:57 PM
