DC 8, 500Hz? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 06-05-2011, 12:04 AM
Matt3824's Avatar
0/11 sssss3754
Default DC 8, 500Hz?
Ok so I've had inputs as to midbass and some people say its ok to use a sub and others say not to, but I'm only going up to 500Hz, so I think it'll be fine in my application. Im using cadence mids and highs and DC subs so I'm either using a Cadence CVL8(500rms, 20-500Hz) or a DC Lvl 2 8, (300 RMS(500 realisticly), and I dont know how I high the Dc 8 will get. I'd rather use a DC 8 because I've used them for small setups before but if I have to use the Cadence, I will.
So the question is, will a DC 8 go up to 500Hz?
Old 06-05-2011, 12:24 AM
Millertime1028's Avatar
0/11 ssssss410
Will it go up to 500hz? Yes... Will it sound good doing so? Most likely not.. With an FS of 36hz it's intent is not as well suited as a dedicated midbass would be in your application. Give it a try though as you may be surprised. Just use a steep slope on your crossover if possible.
Keith Miller
Team L.I SPL
Team DC Audio
(12) DC XL m2 12's - 2:1 ratio 4th order. (3) DC 9.0k's wired @ .5 ohms each. (14) XS power d1400's charged at 16.6v by (2) Mechman 370a alternators. 162.8 legal on music
Old 06-05-2011, 12:50 AM
0/11 ssssss165
agreed.. why would you want it to play that high anyway mind i ask?
Old 06-05-2011, 01:04 AM
Matt3824's Avatar
0/11 sssss3754
Okay, so what about these?
CVL84MBX - Cadence Sound Store
Old 06-05-2011, 01:18 AM
0/11 ssssss165
that should do much better. sadly the link to the specs sheets doesnt work but amazon says they are up to 8k. i tired what you were looking at doing with diff equipement and all i can say is getting a midbass driver over a sub does wonders. i tried a rockford 8" HX2 and up to 250hz and it didnt sound good at all. played it but not well. so i went with the hertz hv 200 8in midbass and while i have it crossed over at 400ish it will easily play higher then that and sound good doing it
Old 06-05-2011, 01:30 AM
Matt3824's Avatar
0/11 sssss3754
Ill probably get those then.
Old 06-05-2011, 03:38 PM
mhart's Avatar
0/11 ssssss721
what makes one 8" be able to play mid-bass and one not? if it's just spiders or something like that i'm sure they can make one to play it.
'00 civic si IASCA stock trunk/pickup 1 World Record Holder
'01 S-10
Team DC Audio Team XS Power Team ISB
Steve's Body Shop
Old 06-06-2011, 05:00 AM
0/11 ssssss165
just a different engineered product. idk the specifics. like DD has a 2500 sub and a 2500 pa driver. just different soft parts
40 cube fart box, single woofer, 500hz. terra Miscellaneous Build Logs 25 06-30-2011 03:34 PM
