need lv5 knowledge - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 06-06-2011, 08:13 PM
bassbear007's Avatar
0/11 ssssss745
Default need lv5 knowledge
This will be my first DC sub. I am getting a lv5 motor and 18" basket and d1 recone from rusty, this is going in an 02 s-10 ext cab and run on a DD z1 @.5ohms, 2xs 3100s 280amp alt lots of 1/0 wire. It will be mostly for a daily driver but will do as many shows as i can so I need good #s. I'm thinking 6cf after sub forward ports up.Will 4 4" areos tuned to 36hz be enough for 1 18 in 6cf. Any ideas or info will be greatly appericated
2002 s-10 ext cab
Kenwood hu
Old 06-06-2011, 08:17 PM
surreal's Avatar
0/11 sssss2489
Would just go with two 6s or a slot port. 6 Cubes is a bit big. The lvl5 has a HUGE motor and I can pretty much guarantee you itll like smaller boxes.
Especially on the Z1 at .5. Id go with around 4cubes at whatever tuning you feel fit.
Old 06-06-2011, 08:53 PM
0/11 ssssss745
Thanks like I said I haven't used any DCs yet trying to find out what they like, tuning wise box size port area that kind of stuff. The reason I was thinking about 4 4" ports I can get them at a good deal.
2002 s-10 ext cab
Kenwood hu
Old 06-06-2011, 11:34 PM
thorshammer's Avatar
Loyal Member
0/11 sssss2315
Well.....
In most cases I recommend 5.5cu for a lvl 5 18. With the power your gonna have on tap and that low of tuning I'm thinking 5cu after port displacement. Did ya discuss with Rusty about how many spiders to run? I recommend 5
Team DefJ
First Trunk in Iasca IDBL Bassboxing History to Average a 150+ after all 3 rds.
152.2 Legal Pr. of 10's out of a Trunk
153.1 Certified DbDrag Pr of 12's
Ported and Powered by Psychoacoustics
Old 06-06-2011, 11:39 PM
Matt3824's Avatar
0/11 sssss3754
Hmmm. I never thought about modding the subs to adapt to the power I'm running. So thorshammer, how many spiders would you suggest on 2 DC XL 18s at 31Hz on 4500RMS?
Old 06-07-2011, 06:05 AM
0/11 ssssss745
Thor I haven't called rusty yet was just trying to get a idea on about how a recone would cost. still have to pic up the motor, will get with you or rusty and figure out what will work best. Thanks for your suggestions so far like I said I know next to nothing about what DCs like.
2002 s-10 ext cab
Kenwood hu
Old 06-07-2011, 07:04 AM
surreal's Avatar
0/11 sssss2489
Take a look at the TC 5200 and other large-motor subs. They like small boxes, and thats generally a property of these types of subs with strong motors and a tight gap.
Four cubes IMO should be fine. Five would decrease power handling but it would give you a bigger peak down low, if thats what you want.
Old 06-07-2011, 08:51 PM
0/11 ssssss112
the 5 cubes w 5 spiders should do very well if you want a lil higher numbers tune up around 38 with decent port area around 16"sq per cube but if ya want to crush the lows and be loud doing it tune around 35hz and give it plenty of port 18"sq per cube area. it will take a good lil bit to loosen up that stack of spiders, but once they do with that kinda power it should be a beast keep it clean and she'll love you long time. just my 2 cents
Old 06-07-2011, 09:51 PM
0/11 ssssss745
Thanks everybody this is the kind of info i'm looking for keep it coming
2002 s-10 ext cab
Kenwood hu
Old 06-08-2011, 01:37 AM
The A Team's Avatar
Active Member
0/11 ssssss817
To keep that sub lively for intense daily abuse i would suggest looking into the ELSP upgrade for the suspension. Now you are going to ask what is ELSP? Extended Life Spider Pack. It is something we have been working on to keep the suspension "fresh" longer under high demand use.
I play lower, louder, and longer thanks to
Stetsom amplifiers
Anyone have knowledge of SUBZERO? kmanian1 General Car Audio Discussion & Questions 9 05-20-2011 11:35 PM
Trade between c_nitty and knowledge c_nitty Trade Agreement Forum 6 04-13-2011 05:49 PM
test your bug knowledge michael707 Off Topic Chat 11 02-08-2010 09:34 AM
Anyone with knowledge on the KA24DE? Drunken.Swagger General Automotive Chat 2 12-08-2009 12:40 AM
Any Ford people with any engine knowledge? tc3k101 General Automotive Chat 11 12-16-2008 08:38 AM
