level 5 take 3500rns? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 06-29-2011, 12:01 AM
crunkjuice1's Avatar
0/11 ssssss809
Default level 5 take 3500rns?
If I get a 15 that can be wired down to 1ohm can it take 3500rms daily?
Old 06-29-2011, 12:07 AM
Nebraskachevy's Avatar
0/11 ssssss518
box size, amp, electrical to back up amp?
Ford Ranger
AQ1200D + AQ HDC318
Treo ssx100.b, Big 3 in KCA 1/0, 2/0 Welding to Back Battery
Sundown Sax100.2 + Crescendo CCX6.5
139.2 @ 41 Hz, Wired to 2 ohms
Old 06-29-2011, 12:17 AM
0/11 ssssss809
xspower S3400 under hood D1200 in trunk 240 mechman alt big 3 1/0 batteries in 1/0 in parallel directly to each other 1/0 to crescendo BC3500d at 1 ohm box if it would take the power I'm asking about will be a paid for design specifically for the sub in ultra badass hatchback with custom dents and roll away tires kenwood headunit clarion EQ rockford rcas cadence 8 gauge speaker wire 300 amp fuse at front and rear batteries.
Old 06-29-2011, 12:20 AM
0/11 sssss8594
Feedback Score: 55 reviews
i didnt understand half of wat u just said...the lvl 5 will laugh at 3500w...so yes, it will take 3500w daily, even tho ull never see that much power after rise
Enclosures
Old 06-29-2011, 12:22 AM
0/11 ssssss809
XSpower told me in a phone call my the electrical I have is fine for what I want to do aside from all the crumbs I have all over the carpet.
Old 06-29-2011, 12:23 AM
0/11 ssssss809
Thank you very much 22! I will keep the box rise in account when I talk to whoever I decide will design box.
Old 06-29-2011, 08:37 AM
Chode69's Avatar
0/11 ssssss234
this
05 Dodge DurangHo
-2x DC Neo 18"
-2X DC 5.0k Amps
Need DC Gear? Hit me up for pricing!!!
Old 06-29-2011, 08:56 AM
1loudyukonxl's Avatar
0/11 sssss1569
Do to lvl 5 having very lose soft parts and a very high motor force your rise is going to deffintly going to be and issue I would expect you to see around 2000 to 2500 rms and rise to 3 to 4 ohms so to answer your question enless you play music way below your boxes tuning you will be ok if you don't clipp it to death
4 custom ia warden 18s d2
box 16.1 cubes 207 inches port 34.6
8 saz2500ds strapped at 1 ohm
21 kinetik 16v 3 dr44 alts 11 runs 1/0
high amps sax 200.4 sax 125.2
4 6.5 beyma g40s 4 10 o2 pros
tweets oldschool earthquake aka screamers
current spl on term lab 158.1 db at 37 htz no wall
Old 06-29-2011, 04:53 PM
0/11 ssssss809
that rise thing sucks. so even wired to 1 ohm the amp will be putting out only 3 to 4 ohm load? From this point on I will need to buy a lot stronger amps just to get the rms value at a certain ohm load after rise?
can anyone list a mockup sub or subs and amp combination that would be putting out actual 3500rms in a daily driver?
Old 06-30-2011, 02:41 AM
Zooook's Avatar
1337 M3mb3r
0/11 sssss3991
Feedback Score: 31 reviews
Wire to .5 and you will see more power.
EDIT: that's if you don't already have the lvl5 then just order a d1 coil sub and wire to .5. Just make sure your not dipping to low on volts and amp isn't getting hot. Probably void the Warranty on the amp though.
ALL FOR SALE ALL FOR SALE PM ME FOR PRICES
2003 BMW 330I
2x12" AB HD/W DC XL recones
18" DC Level 4 w/Fresh Level 5 recone ridin4deep 18" Subwoofers 20 07-21-2011 06:10 PM
[SOLD]3 DC Level 4 18s Dual 1 With Level 5 Coils fijunkie88 18" Subwoofers 25 02-04-2011 02:55 AM
whats the difference between a level five and a level four with a level five coil? mattintc10 (DC) 29 02-03-2011 12:12 PM
[Sold](2) DC Audio Level 3 12s with Level 4 D1 coils Like New! toaster 12" Subwoofers 12 03-30-2010 08:09 PM
[TRADED] DC level 4 15's w/level 5 coils and xtra spider Violence* 15" Subwoofers 16 01-16-2010 12:53 AM
