Box size - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 08-08-2011, 12:49 PM
0/11 ssssssss8
Default Box size
For anyone that has experience with the level 4 12's what is the recommended box size. I will be running two of them on a 2.0K. I drive a regular cab f150 and I already have a box that's about 3.6 cubes tuned to 35 hertz with two 4" upfiring aeroports. It was built by Dave the box guy.
Old 08-08-2011, 01:11 PM
taylorpro's Avatar
^ Mr. Creativity ^
0/11 sssss6033
that would work fine. you could make a bigger one tho if you wanted. you arent running over rated power so you should be able to gain some low end out put with a little larger box and lower tuning. all depends on your goals though
-Youtube Channel
Old 08-08-2011, 04:53 PM
0/11 ssssssss8
Ok thanks ill try mine out first and see how it goes.
Box size spm_215 (DC) 3 04-25-2011 05:08 PM
box size Fosgate1 General Car Audio Discussion & Questions 4 03-15-2011 08:03 PM
box size? thekernal123 Enclosure Discussion & Design Construction Help 0 03-14-2011 10:49 PM
Box size help RYDOGG2992 General Car Audio Discussion & Questions 0 02-22-2011 10:25 PM
box size help? luises14 Enclosure Discussion & Design Construction Help 2 08-12-2010 08:37 PM
