Suggested SPL Box For Me? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 04-24-2009, 01:15 AM
NoPh33rRaCiNg's Avatar
I <3 ( . )( . )'s
0/11 sssss3010
Feedback Score: 29 reviews
Default Suggested SPL Box For Me?
Rusty, or anyone wanna chime in on what would be the best straight spl box for 2 lvl 4's w/lvl 5 coils off 2krms. I was thinking somewhere around 38hz, not sure how many cubes? and slot ported is easiest ive never used aeros. Not sure if tuning higher than 38 would be best for these...
Team DC Audio : Team NWSPL : Team Shok
02 Tahoe - (1) 15'' XL, Shok II, Shok 1/0
03 S10 (in progress) - (3) 15'' Lvl5's, (2) DC 5k's, lots of Shok 1/0
Old 04-24-2009, 01:16 AM
straight spl try starting at 50 and work your way up till you peak
Old 04-24-2009, 09:56 AM
The A Team's Avatar
Active Member
0/11 ssssss817
Forgot to mention you have 15" subs and a Blazer.
I have done street A in mine with pair of 10s in 2006 got up to 152.7 certified with a Z1 and 9910s. Not to mention i did that # from a wheelchair lol. Used 1 cube per sub common chamber and a pair of 6" aeros, subs firing towards the passenger side ports to the drivers side. This worked best in my blazer but have tried it in other peoples and port back seemed to be better in theirs. Truth is you will have to test that out yourself to know for sure. Cause in mine i gained 0.2 over rear firing port but other blazers seen it lose them 0.5! Also mine peaked 56 Hz, my ports peaked @ 57Hz on paper.
Now for you i would do like 2 cubes per sub common chamber to start. If you are going to use a slot do it external, you will see a gain in efficiency from that. Do as much port area as you can and tune in the 50-58 Hz area. I have never seen a blazer peak under 52 Hz for burps.
Here is a pic of my loudest street A box. Similar to what crx guys were using but doesnt work the same in a blazer thats for sure.
Old 04-24-2009, 10:03 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
Feedback Score: 88 reviews
i remember woofercooker on ca told me the same.
i'll find the link to the thread, i asked a question similar.
92 Ranger Walkthrough
(Under Construction)
RidnClean's Avatar
Ballin
0/11 ssss17858
96-01 blazer owners - Car Audio Forum - CarAudio.com
Old 04-24-2009, 10:21 AM
The A Team's Avatar
Active Member
0/11 ssssss817
What about this box it beat up granmas it was so crazy! hahaha
Old 04-24-2009, 10:24 AM
The A Team's Avatar
Active Member
0/11 ssssss817
this box i used in a MX3 in 05 to break a 150 in street B, but then i ended up using it for daily in my blazer blocking 1 sub hole and running a single 9512 on a Z1 daily 2.8ohm tuned to 42 Hz burped a 148.8. It was was 1.7 cubes net volume.
Old 04-24-2009, 10:27 AM
The A Team's Avatar
Active Member
0/11 ssssss817
Also have this box here currently in my blazer for daily with a pair of DC lv3 12s in it. Tuned 40Hz i would say it does 147 to music but have not metered it but my ear is pretty close most the time. Geez you got me digging through old box pics now. ;P
Old 04-24-2009, 10:31 AM
The A Team's Avatar
Active Member
0/11 ssssss817
Here is another daily build box did 150 to music 9918 on a Xfire 4000d. I didnt like this one though having everything up i thought it should have been alot louder.
Old 04-24-2009, 10:33 AM
RidnClean's Avatar
Ballin
0/11 ssss17858
i can tell by ear that sub/port up isn't loud.
Suggested Fuse Sizes Patrick Simmons Tutorials & Quick References 1 11-11-2008 03:14 PM
