Box size for a pair of XL 15s ok? - Car Audio Classifieds!
(DC) DC Audio's Online Forum
Old 08-15-2011, 12:56 AM
0/11 sssss2148
Feedback Score: 26 reviews
Default Box size for a pair of XL 15s ok?
This is my old box I had built by Mike at AMI Creations last year, its a bit over 6 cubic feet net with 68 of square port tuned to 32hz.
I was wondering, would this be ok for a pair of XL 15s on a Crescendo 3500 @ 0.5 ohm? (about 4k RMS). Could I use a Crescendo 5500 on the pair in the same box @ 0.5 ohm? (About 5500w RMS)
I pmed Rob aka Thorshammer a while ago about it, and I want to say he gave me the thumbs up on the box, but I deleted it a while ago and wanted to make sure before i commit to this, lol. Thanks.
Old 08-15-2011, 01:01 AM
Prohibited Sellers/Buyers
0/11 ssssss607
It will work. but could do much better. Like around 7 cu ft with like 100 sq in of port tuned from 32 to 36 would be nasty off that power
Old 08-15-2011, 11:54 AM
Droppin' HZ Car Audio
0/11 sssss1596
that box will be just fine and will be even better off of the 5k amp. Normally I would recommend about 3.5ft3 per sub after displacements and 16-18in2 of port per cube.
Old 08-15-2011, 12:32 PM
0/11 ssssss283
12 to 16 inches of port per cube is the general "rule"...but most tend to go a tad more port area 18 to 20" sometimes for that deep rich sound but make the woofer unload more..
the box u got would work yes..but its got minimal port area n id use the 3500d at 1/2ohm ..save money over the 5k amp and do basically the same thing..bc ud never notice the 1k rms differance to the ear lol
Old 08-21-2011, 03:57 PM
0/11 sssss2148
Thanks for the info fellas and sorry for the delay response, just been a bit tied up.
If i go this direction, ill prob go with the 5k at 1ohm, I agree with you Jacobs93, I wont hear the 1k difference between the two amps, lol, but the 5500 making the power @ 1 ohm will be a bit easier on the subs esp the leads.
If I wanted to do something for a daily box, how would 6 cubic feet tuned to 35hz using (2) 6" areo ports do?
Old 08-21-2011, 04:00 PM
thorshammer's Avatar
Loyal Member
0/11 sssss2315
Box will work just fine although like stated would prefer more port area. 2 6 in aeros will also work well.
Team DefJ
First Trunk in Iasca IDBL Bassboxing History to Average a 150+ after all 3 rds.
152.2 Legal Pr. of 10's out of a Trunk
153.1 Certified DbDrag Pr of 12's
Ported and Powered by Psychoacoustics
SA 15s box size and port area help?? tez4life (Sundown Audio) 4 05-20-2011 04:49 PM
[SOLD]Pair of DC Level 5 15s defj165 15" Subwoofers 6 02-23-2011 05:55 AM
Box size for 2xl 15s? mads10bass (DC) 3 10-07-2010 03:35 PM
Quote for a pair of 15s PSI style... tez4life (PSI Car Audio) 4 02-22-2010 11:21 PM
